Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
(HVAC) Furnace Not Igniting Quickly
Carrier // Day & Night // Model 397HAW036060 (1982)
Furnace doesn't seem to be Igniting Correctly.
Blower comes on and runs for about 10 minutes, Furnace starts ignition process, it ignites-then ''Blows-Out'', repeats this same process 6-9 times before Ignition is Constant, meanwhile Blower is Blowing Cold Air. Isn't this condition wasting Gas? How can I Fix?
3 Years ago the Electronic Control Board was Replaced, 2 Years ago the Control Valve & Blower Motor were Replaced. Checked the Igniter and it ''appears'' to be working Correctly During Cycles.
  • Rick Wymer
    Rick Wymer Jan 08, 2009
    No Back Draft. So, which Part would need replaced, and How to do that?
  • Rick Wymer
    I keep coming up with "other" responses, that the Burner is supposed to Start BEFORE the Blower comes on, is that Correct? and How to Fix that?
    At present the Blower comes on 1st (Hi-Speed), and runs 10-12 minutes BEFORE the Burner starts Cycling, Guess I'm getting confused...
    Scholar:
  • 39 Answers
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Posted on Jan 08, 2009
  • Ty Parcher
    Ty Parcher Jan 08, 2009
    I used your model number as a Google search key. I got a hit on your service manual pdf. It describes how to removed and clean the burners and pilot assembly. The flame sensor is described as a switch but its not more specific than that. Clean the pilot assembly and the burner orifices paying particular attention to the orifice hold that are close to the pilot as this area may accumulate extra deposits. If that does not fix the problem then replace the pilot assembly which includes the sensor. The Service Manual is very specific about how to remove the burner and pilot including pictures but if you need more help than that write back.
  • Ty Parcher
    Ty Parcher Jan 09, 2009
    You have two "blowers" in the unit. One is to move are over the heat exchanger (room air, big one) and the other is to move air through the burner chamber, then through the exchanger to extract heat, then to the exhaust flue (the draft blower, small one). The furnace must establish good draft before ignition or bad things will happen. There is a draft sensor (switch attached to a plate in the draft system that senses good air flow) to prevent this. If the draft fails or is weak after the burner is on then the draft sensor opens and cuts off the natural gas (or propane). The burned flue gases coming off the burner do not get mixed with the air in the rooms of the house. A heat exchanger keeps the hot burner gases and the room air separated from each other. If there is a hole in the heat exchanger you can get carbon monoxide poisoning in the room therefore the heat exchanger has to be clean and sealed tight. You may have a problem there if the draft fan or flue is full of dirt or otherwise obstructed and does not give the flue system good steady air flow. That can shut off your lit burner early.
    If the room air blower starts up on a cold furnace the rooms will get a cold air draft because the heat exchanger in the furnace is still cold. Therefore the furnace is designed to heat the exchanger first with the burner gases and them start the room air blower up on a delay or at a set exchanger temperature (your case I think). That way hot air comes out in the room air ducts almost immediately. Your draft blower starts before ignition. The room air blower starts later.
    There was a bad typo in my last posting. I typed "orifice hold." That should read "orifice holes"
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
Furnace won't come on after being off several hours, new relay
Lets test the t-stat. Take the cover off the stat locate the terminals R & W take a small piece of wire and holding the wire jump across the two R & W terminals. Does the furnace start up immediately? or does the same problem exist? Sometimes in diagnostics you have to start to eliminate the problems one by one. ken
Jan 01, 2009 | Carrier 38CKC048 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
984 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
