Question about Medion Computers & Internet
PC keeps freezing on boot up
I have a Medion tower (mt6) & it keeps locking up when trying to start.. I have tried a new HDD ..... replaced the CMOS battery ...... cleared the motherboard by removing the jumper [on the J1 connection, i think it was called, by the CMOS battery] ..... All to no luck!
Any other ideas?????
  • problem3pc Jan 09, 2009
    Thanks, yes the pc does startup in safe-mode (normally on the 2nd attempt & I MUST LEAVE THE 30 SECOND COUNTDOWN TO RUN DOWN TO ZERO) ...... I also tried to boot up to a Ubuntu HDD, but it hung again.
    I'll try a windows repair (from the CD) but don't hold out much hope for it.
    Novelist:
  • 93 Answers
Let's narrow the problem down a bit. The biggest clue will be "where" it hangs in the boot process.
1) During (or before) the POST (power on self test).
This would signify that you have a hardware issue. Often, the system will beep at you, and you can decipher those beeps to figure out the problem. Some things that will cause a freeze here are your video card, RAM, the CPU, or even a fan (especially the CPU fan).
a) Video - if you are seeing anything on your monitor, it probably isn't video. If not, replace the video card (if using the onboard video, add an outboard card. If using an outboard card already, then swap it out with another one, boot, and see what happens.
b) RAM - swapping out chips is the only way to test it, unfortunately.
c) CPU Fan - Eyeball it and see if it is spinning. A fan failure will instigate an immediate shutdown, to prevent the CPU from burning up.
d) CPU - Another tough one. The only real solution is to replace it with another one, and see if the system boots.
If it seems to be none of the above, it may be the motherboard itself that has an issue. Once you try all of the above, you can be more certain that it is indeed a bad board.
2) During Windows startup.
This would mean you have a Windows problem. Often, a new driver or some new piece of software can alter things enough to cause a hang. Attempt a boot in safe mode (which loads only default drivers), or even restore the OS to an earlier point. If you get a BSOD (blue screen of death), you'll want to look for the error code on the page, as it will at least give you a clue as to where the problem is. Another option is to boot from the Win Install CD, and effect a Windows repair. This will fix an awful lot of problems.
Cheers
Nick
Posted on Jan 08, 2009
System will not boot. lights come on, disk light on for two seconds then stops. Other lights stay on. This is the same when just AC adapter is being used. Tried reseating and testing RAM. It will try...
Take out dvd-rw drive, wifi card, hdd and check usb ports for bent pins. Try booting to cmos with old memory. If this doesn't work, try new memory and cmos boot. If laptop boots to cmos, motherboard is probably okay. If not you may have MB problem. If it boots to cmos, add removed items back one at a time.
Mar 22, 2015 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
Install replacement HDD with Windows 7 but won't boot
did you ghost copy the windows 7 to the new drive or reinstall with cds
Dec 18, 2017 | Medion M3 Composer 5200 PC Desktop
My Medion laptop won't boot windows; black screen
Unplug, remove battery, Remove and reseat Memory Mods, try to reboot. If no, Remove HDD and test, replace if necessary. Has their been any damage? Dropped?
Feb 02, 2013 | Computers & Internet
Hvor finder man en grafikkort, der kan bruges i en medion pc mt6???
Hej, hittade ett kort som passar till min medion mt6, hittade den i webhallen.com,
kortet heter:
Sparkle Geforce 8400GS 512MB (SP84GS512S3LNMP) PCI / DVI / VGA / HDMI.
Fungerar hur bra som helst och installerar sig nästan själv.
hoppas det hjälper.
Dec 15, 2010 | Computers & Internet
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
Laptop locks up constantly, even during boot from HDD or CD.
Don't upgrade the OS. Try upgrading your RAM. This should the computer to process more and therefore stop it freezing as much. Also don;t run too many programs at once. If you are looking to keep a laptop for the furture invest in a new one. go to http://www.crucial.com/ fo RAM.
May 03, 2009 | Computers & Internet
Computer freez
well u could try going into ur bios befor it freezes and make it boot from the win98 cd instead of ur HDD or use a boot disk or just take ur cmos battery out and it will reset ur bios so it should work
Jan 13, 2009 | Computers & Internet
My medion pc keeps freezing/slowing down everytime I turn the pc on. Windows loads up with what appears to be no problem then it stops working.
LadyTech99
Rank:nonexpert_s.gif Apprentice
Rating: 78%, 2 votes
Sounds like you may have a virus. It could be a memory issue. If you know a tech have them try also try recovery console/fixmbr/fixboot. This will write a new master boot record which does get corrupt and keeps the OS from booting up. At the same time have them do a REPAIR of your operating system. If all else fails REINSTALL.....
Jul 04, 2008 | Medion Computers & Internet
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
Computers & Internet Logo
577 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
