Question about Mitsubishi HS-U445 VHS VCR
Vcr displays message flashing E 5 on front panel. tape is moving but no picture. what gives? was working fine 2 days ago, went to watch a tape tonight and nothing happened but this message where the channel display is
  • Anonymous Mar 10, 2008
    e5 is flashing cannot do anything, cable is directed through the vcr
  • 883 Answers
Unplug it for 30 minutes and retry...any luck?
Posted on Jun 01, 2007
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
C:32:23
This is a common problem with alot of Sony CamCorders...The solution is simple.....GIVE IT A WHACK!!!
Seriously, Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.
works in 90% of cases!!!
Sep 22, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Apr 19, 2008 | Philips VR620CAT VCR
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
ZENITH VCR TAPE KEEPS EJECTING
Got pets or young ones? This problem just smacks of having something lodged inside. Could also have come from a label coming off inside, too...accordianman
Jan 19, 2008 | Zenith VCS442 VHS VCR
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Dec 20, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Mitsubishi HS-U445 VHS VCR Logo
221 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
