SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
SOURCE: pxe-e61 pxe-m0f error with boot up
Error from boot??
Is that a problem when loading on POST? or you got problem on boot on your Operating System..
Please specify...
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive..
If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
SOURCE: pxe-e63 and pxe-m0f errors
enter to boot up in safe mode, then disable the atheros network drivers in my computers properties > hardware or drivers, then leave the originals that it came with should be the first two, ok, remove all others that say atheros, This error is of a group of driver programs being installed in computers through networking, yes hackers, I've fixed about 10 computers this month, but this software seems to log in to a network that can monitor your activity. Made by Atheros, & probably hacked to do this, cause Im sure the company did not modify this to log in to other private networks, if networks or drivers are disabled it will not even but up so best thing is to go into safe mode & disable these atheros drivers that dont belong in the computers in the first place. I had to re-install the bios in pcs because it modifies bios, registry files, and once t does that, its hell for the not so tech savy normal person.
SOURCE: When I turn on my Acer minilaptop it say: Check
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
