Wire colours are as follows:
Left Controls
Orange/white = accessory power
Blue = Headlight Power
Yellow = Low Beam
White = High Beam
White/Purple = indicator left
Yellow/Black = Horn
Black/Red = Clutch Lockout
Black = Ground
Grey/Green + Green/Blue + Pink/White + Brown/Black = Radio Control
Orange/Black + Purple/Black = PTT and squelch
Right Controls
White/Brown = Indicator right
Red/Yellow = Stop Lamp
Grey = Ignition Power
White/Black = Run Switch
Black/Red = Starter Switch
Blue/Black + White/Blue = Cruise Control
Brown/Black + Pink/White + Grey/White + Brown/White = Radio Function
2000 Jeep Grand Cherokee Stereo Wiring
Constant 12V+
Red/White
Switched 12V+
White/Red
Ground
Black
Illumination
n/a
Dimmer
Orange
Antenna
Right Front
Front Speakers
6" x 9" Doors
Left Front (+)
Light Green/Red
Left Front (-)
Light Green/Green
Right Front (+)
Light Blue/Red
Right Front (-)
Light Blue/Black
Rear Speakers
6 1/2" Rear Door
Left Rear (+)
Dark Green/White
Left Rear (-)
White/Dark Green
Right Rear (+)
White/Purple
Right Rear (-)
Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
yellow to yellow main power wire red to red key wire black to black ground speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground orange is dimmer switch you wont need it blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
FOR 16-PIN HARNESS
Pin NumberWire ColorFunction
1 White Left Front (+)
2 Green Left Rear (+)
3 Violet Right Rear (+)
4 Grey Right Front (+)
5 Blue/White Amplifier Remote
6 Blue Antenna Remote
7 Red Accessory 12 Volts
8 Black Ground
9 White/Black Left Front (-)
10 Green/Black Left Rear (-)
11 Violet/Black Right Rear (-)
12 Grey/Black Right Front (-)
13 Sky Blue Telephone Mute
14 Orange/WhiteIllumination
15 Not Used Not Used
16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
1 Not Used Not Used
2 Black Ground
3 Grey Right Positive
4 Grey/BlackRight Negative
5 Blue/WhiteAmplifier Remote
6 Red 12 Volt Switched
7 Yellow 12 Volt Constant
8 White Left Positive
9 White/BlackLeft Negative
MAY THIS HELP YOU
