Question about Packard Bell Easy One Silver 2120 Notebook
I have no sound on my computer
One message come on my computer for updating windows media player i was updating it,but now media player is not working and also i have n sound on my pc,i have no sound controls. i have the same problem my computer have a problems in speaker and sound
  • 4 Answers
Go to this website http://support.packardbell.com/global/item/?pn=P470300802&g=2000 and you will see it says sound and download the one for your windows and install you have to install the driver and it should work let me know how this goes
Posted on Jan 23, 2009
Removing Windows Media Player on my Desktop
Method 1: Uninstall Windows Media Player in safe mode loadTOCNode(2, 'moreinformation');
  1. Start the computer in safe mode. To do this, follow these steps:
    1. Restart the computer.
    2. Press F8 while the computer is restarting.
    3. Click Safe Mode, and the press ENTER.
  2. Click Start, click Run, type appwiz.cpl, and then click OK.
  3. Click Windows Media Player 11, and then click Remove.
  4. Follow the prompts to uninstall Windows Media Player 11, and then restart the computer when you are prompted.
  5. If Windows Media Player 11 is not removed, try Method 2.
uparrow.gifBack to the top Method 2: Run a program to remove Windows Media Player loadTOCNode(2, 'moreinformation'); If Method 1 does not work, you can use this procedure to uninstall the core of Windows Media Player.
  1. Click Start, click Run, type %windir%\$ntUninstallwmp11$\spuninst\spuninst.exe, and then click OK.
  2. Click Next, and then click Finish.
uparrow.gifBack to the topTo prevent Windows Update from downloading Windows Media Player 11, follow these steps:
  1. Click Start, point to All Programs, and then click Windows Update.
  2. Click Custom, and then click Software, Optional in the Microsoft Update Home pane.
  3. Expand Windows Media Player 11.
  4. Click to select the Don't show this update again check box.
    Note If the Don't show this update again check box is unavailable or dimmed, click to clear the Windows Media Player 11 check box, and then click to select the Don't show this update again check box.
  5. Click Review and Install updates to save the setting.
Jan 17, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
My computer is a Dell Dimension 2400. Installed ASUS DVD RW drive in December 2007. It seemed to work just after installation but now it does not work. I get a Windows Media Player Error Message...
But can you still use the DVDRW right? the only problem here is you cannot use media player because of the error message? Because if the DVDRW still read and write so there's no problem with it the problem is with the windows media player, Try using a different media player like VLC.
Hope that helps.........
Aug 11, 2008 | Televison & Video
No audio file will play on WMP, no dvd or audio disk will play...
Windows Media Player cannot play several files in the playlist. This might be caused by one or more problems.
To find information about the specific problems, click the Now Playing tab, and then click the blue or red icon next to each file in the List pane.
In some cases, you might encounter this error message if there is a problem with your sound device, such as a sound card or sound controller. For example:
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update or see the sound device manufacturer's Web site.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Shuts off when turned on
You can definitely use Windows Media Player - in fact, it is the reccomended program.
From your description, it sounds like you might have turned your mp3 player on before fully charging it. Let it charge for 3-4 hours before adding music or doing anything else. The "updating" message will eventually go away as long as you don't unplug the player from the computer before it finishes updating. If you do unplug the player from the PC while it is updating, you will effectively destroy your GoGear.
-Tha Mp3 Doctor
Feb 09, 2009 | Philips GoGear SA3245/37 Digital Media...
Windows is not genuine so media player doesnt update
you need to buy original version and enjoy the benefits from Microsoft, there is no other solution to originality
Jan 29, 2009 | Iomega Zip Tools (10202) for PC
Audio
try to uninstall the software and then the soud card of your computer.. then attach it again and install the software.
Mar 25, 2008 | Microsoft Windows Vista Ultimate Edition
I can not play audio files
In the windows media player go to > now playing - more options - devices - speakers then changed the audio device to use your soundcard.
Also, uninstall any other players, they usually interfere with each other.
Mp3
Follow these steps:
CLICK Here to Download : Firmware Update
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 04, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
A Solution To A Connection Error With Windows And The Player
I followed all the steps and nothing is happening. Help....
Dec 17, 2007 | Samsung YP-U2X Digital Media Player
Packard Bell Easy One Silver 2120 Notebook Logo
85 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
