Question about HP Multibay (DG189A) DVD-RW Burner
MultiBay drive will not allow me to copy on to CD
I got this computer as present for christmas, has multiBay, it is a HP L1750 Microsoft XP home edition, I can play CD no problem but when I go to burn a CD or copy photos to CD the PC tells me put CD in Drive D when I already have one in. I am getting annoyed I must be doing something really stupid. Please help!!!
    Problem Solver:
  • 11 Answers
You may not have the correct discs,check type of discs it takes,ie CD-R,CD+R,CD-RW,CD+RW.
Posted on Jan 08, 2009
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
My Windows XP Home Edition(licensed version) does not boot (hangs) does not go beyond desktop, I have to reset which leads to checking the drives. A windows 7 has been copied to a drive which is working...
First of all you need to have the Windows XP cd to install it on your computer. And also if you have the copy of the of the product key to reacvtivate it again. that is all you need to reinstall XP again on your computer. You will also need the drivers cd for the computer to function again normally.
thank you for using Fixya. you recommendation is highly appreciated.
Sep 27, 2010 | Microsoft Windows XP Home Edition
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
I qant to install windows xp
Get a bootable windows xp cd first.
Boot the computer and enter the bios.
Change the boot priority and make the computer boot through the optical drive.
Then save settings and reboot placing the cd in the drive.
The computer will boot through cd and show the main menu which allows you to format and install the xp select install and you will be able to do so
May 02, 2010 | Microsoft Windows XP Home Edition
I just purchased Microsoft Home and Student 2007 and cannot install it beacause my CD Drive does not work. Can I install with product key?
Dear sir,
According to your problem solution is Copy content of the MS-OFFICE 2007 CD to a Pendrive(Thumb Drive) from other computer having working CD ROM.Then connect thumb drive to your computer install MS-OFFICE through Setup file present in the thumb drive,if it asks product key give the product key printed on MS OFFICE 2007 CD envelope. It solves your problem.
Good luck
Fixya Customer Support
chandrashekahr
Jul 29, 2009 | Microsoft Office Professional 2007 Full...
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
How will i restore deleted userinit file in system32 folder?
Insert the original Windows XP CD (Windows XP with Service Pack 2 is preferred, but not required) and reboot the computer. You may need to configure your computer to boot from the CD-ROM drive.When the Windows XP Setup has started, press "R" to "repair the Windows XP installation using Recovery Console".
Select the Windows installation to repair (generally this is C:\Windows) by typing its number and then pressing ENTER.
Type the Administrator password and press ENTER.
Type the following commands:
D: [ENTER]
CD I386 [ENTER]
EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32 [ENTER]
NOTE: If your CD-ROM drive has a different letter assigned to it, enter "X:" instead, where X is the appropriate drive letter.
After entering "EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32" you should see the text "1 file(s) copied", in which case all went well.
Remove the Windows XP CD, type "EXIT" and press ENTER to restart your computer. You should now be able to log on as normally.
Mar 05, 2009 | Microsoft Windows Vista Home Premium with...
I use hp pc computer with xp windows and cant use hp photosmart 7760 printer . how can i setup this printer 2 ma software ??????
Find another HP Printer Driver that will allow you to have most of the features you had. You always seem to lose features when dealing with this. This is your only option. Search the HP.com website for suggestions. Put 7760 and XP in the search box.
Jan 20, 2009 | HP COMPAQ Floppy Drives ADAPTER MULTIBAY...
HP Multibay (DG189A) DVD-RW Burner Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
