I browsed Motorola vonage gateway and I get a result the phone is idle. How to activate the phone.? This problem is recently occurred.
SOURCE: i am unable to instal motorola vonage modem Vt2142
hi try 192.168.1.1
hope this helps
cheers
SOURCE: setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
SOURCE: The PC/ACTIVITY my Motorola modem isn't on...
if all of the other lights on the modem are lit, except pc activity, that means the modem isnt communicating with the computer. 3 things can cause this - modem could be bad, ethernet cord could be bad, or the NIC card(the card in the cpu that houses the ethernet port) is bad. Most of the time its the ethernet cord or the NIC card in my experience. Dont fret, both of those are relatively cheap fixes.
