Canon EOS 30D Body Only Digital Camera
Problem for Canon EOS 30D Body Only Digital Camera
Canon EOS30D: Overexposure in Auto Mode
By chrisemswort on Jan 08, 2009
My EOS30D appears to over exposure shots by about two stops when in the green box 'idiot' mode. At first I thought this was a result of unusual light conditions in a coastal location, but it is also doing it in 'unambiguous' locations too which should not poase a problem. Paradoxically, when shooting landscapes I've found the best of the 'simple' exposure modes is Portrait. Has my camera got a fault?
I've also been getting ERR99 messages too, even though both of my batteries are fully topped up 9I tried swapping the batteries round).
Recently took it to Cuba with me, where as a result of both problems above, I felt the camera had let me down. Advice urgently needed! Or should I just trade it in for a Panosonic 'bridge' camera.
Same Problem
Mar 04, 2009
-   i have the same problem. -   Guest
Best Solution
posted on Mar 19, 2009
Very Helpful)
JohnLeF
Rank: Guru  Canon Expert
Rating: 90%, 100 votes
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon EOS 30D Body Only
Questions and Unsolved Problems for Canon EOS 30D Body Only
Do you recommend Canon EOS 30D Body Only Digital Camera?
Answer
Answer
When I try to view images on a tv the connection in the camera does not hold and the image does not... (More)
Answer
Describe your how to fix the light meter inside canon 30d slr Problem
Answer
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly... (More)
Answer
after beep sound of focusing,shutter is not clicked
Answer
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon EOS 30D Body Only...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
