Question about Toshiba 57H81 57" Rear Projection Television
57 IN. TOSHIBA HDTV
I ASK ABOUT THE 57IN. TOSHIBA TV WITH THE GREENISH TINT. IT ALSO HAS THE RED AND GREEN LINES GOING THROUGH THE SCREEN. THERE IS STILL SOUND AND THE PICTURE IS ALSO FADDED SO, IF SOMETHING THAT COMES ON HAS A BRIGHT PICTURE IT CAN BARELY BE MADE OUT.
THIS QUESTION WAS POSTED YESTERDAY.
  • Anonymous Jan 19, 2009
    My 57H80 tv is distorted for about 10 minutes when it is first turned on. Then the screen has the sides looking like an old pair of those 3D glasses with red and blue, and doubled figures. When the touch focus button is pushed, it goes through the sequence, then the red lines is squiggled, then reads error. The convergence is so far apart on the outer numbers they don't line up.The set is a little over 4 years old, is it done for or can it be fixed. I paid a small fortune for it, and expected it to last longer than 4 years. any suggestions?
    Sergeant:
    Champion:
  • 267 Answers
YOU HAVE BAD CRTS. THOSE ARE RETRACE LINES YOUR SEEING CAUSED BY SHORTSINSIDE THE CRTS. BUY A NEW SET.
Posted on Jan 23, 2009
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Feb 18, 2012 | Hitachi 57S700 57" Rear Projection HDTV
Have 57 " Toshiba projection TV there is way too much red in picture
TV has 3 CRTs, red, blue, green. Its possible that you have a bad blue or green crt. If that were the case the red would be prevalent and the pic would be reddish. The tv has a picture "level" adjustment that if done correctly could get it looking correct. Its probably best to have a tech. do it since you can make it worse if you do not know what you are doing, also there are high voltages present. Good luck
Oct 30, 2011 | Toshiba 57H84 57" Rear Projection...
I have lines on the bottom of my 57in rear projection hitachi tv how do i get rid of them myself
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 57F500 57" Rear Projection...
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Peoples skin turn light green on screen
the cathode tubes are going out you need to replace them. there are three of them and they cost about 300 a piece. probably cheaper to replace the tv.
hope this helped
please rate well.
Mar 04, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I HAVE A 57 IN. TOSHIBA HD TV AND THE TV SCREEN IS A GREENISH
take the front panel off the tv, the bottom, you will see 6 little nobbs :::, use them to adjust your picture, the left 2 should be for red, the middle 2 dlue, and right green, top 3 are for focas, those are probabily the ones you want to adjust, bottom 3 are for turning the colors up and down, mess with those untill pic looks good
Jan 07, 2009 | Toshiba 57H81 57" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Toshiba 57H81 57" Rear Projection Television Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
