Question about HP Pavilion A6010N (882780985575) PC Desktop
Is nvivia gforce 7300 compatible with a6010n hp motherboard
I have tried all i can but there is no signal on my monitor
  • rebelyes1 May 11, 2010
    did you check the vid card on another computer to make sure it works?
  • 47 Answers
If your PC has a built in graphics adapter then the bios and windows will automatically use that as a primary display unit..u need to boot the PC with that and then check in the device manager if the PC has picked up on the new display unit.. if it has then disable the on board one. the pc will ask to restart ... do it.. then when it does connect the monitor cable to the new display device.. and make sure that the monitor has an image of the start up screen if it does then you have completed the upgrade
Posted on Jan 08, 2009
HP Pavilion a6010n graphic card driver is incompatible with CyberLink Power DVD 10
Your pc has an Intel Graphics Media Accelerator 950 video chip, integrated on the motherboard - it's extremely weak and supported only in XP. Its driver can be found here
http://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=16835
But the best solution is to get a new separate video card, one like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6764506&CatId=1826
Sep 13, 2011 | HP Pavilion A6010N (882780985575) PC...
Is gforce 210 1gb is compatible to my k8n neo3?
Yes, you just need to install it into the white Pci-E slot. It should work fine.
May 17, 2011 | MSI K8N Neo3 Motherboard
Is p5sd2-vm graphics integrated mbd supports nvdia gForce 9400 gt.
Yes it is compatible with Gforce 9400GT
the motherboard has 1 PCI Express x16 , 1 PCI Express x1 , and it is compatible...
Hope this helps
Apr 02, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Same as the guy with the Inno 3D 7300 but this time i have a sparkle gforce 9400 i always get a reboot and blue screen
Remove the video card, memory card and then reset your motherboard BIOS and then plug it all again. See if it works.
Oct 30, 2009 | Gigabyte GA-VM900M Motherboard
Aspire, desktop: Screen will randomly go blank, if I turn off monitor and turn back on it says no signal, keys are locked up as well. If there is audio when it does this the audio will start skipping...
have you checked your gforce for power failure? check your powersource for the type. if it is not over 500 Watt.... That is a big problem with system function. If you are using a newer Updated machine, you should always keep up to electrical fashion or your machine will most definitely do "Funky Stuff" quote.
This is also interfering with your soundcard on your motherboard, and if this continues without being checked, your motherboard may blow.
Reg, Jordon
Aug 25, 2009 | Computers & Internet
MSI K8N --Compatible video card
Get another GForce video card a later model with at least 256Mb of memory. If you play games you might want a higher spec GForce video card.
Mar 15, 2009 | MSI K8N Neo4-F Motherboard
HP Pavilion s3050.uk graphic card overheating & black screen
Your card is available at Newegg.com gforce 7300le for $70.     Any PCIe 16 card wil fit you computer just make sure that you have a large enough power supply to handle a card that would use more power.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=gforce+7300le&x=11&y=28
Feb 25, 2009 | MSI GeForce® 7300 LE, PCI Express Graphic...
Installed new video card but the signal remains black
REMOVE THE CARD AND UNINSTALL THE VIDEO CARD IN ADD REMOVE PROGRAMS. THEN REMOVE VIDEO CARD AND INSTALL DRIVERS THEN INSTALL YOUR VIDEO CARD. I HAVE THIS SAME VIDEO CARD AND HAD THE SAME PROBLEM.THIS WAS THE ONLY WAY I COULD GET IT TO WORK. ALSO YOU NEED TO DISABLE THE VIDEO CARD THAT IS ON YOUR MOTHERBOARD. YOU CAN DO THIS IN CONTROL PANEL. ADMINASTRATIVE TOOLS THEN CLICK COMPUTER MANAGEMENT THEN CLICK DEVICE MANAGER GO TO YOUR DISPLAY DRIVERS AND DISABLE YOUR GRAPHICS CONTROLER. THAT SHOULD DO IT. HAPPY NEW YEAR.
Jan 08, 2009 | HP Pavilion A6010N (882780985575) PC...
New wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Nov 25, 2008 | Computers & Internet
HP Pavilion A6010N (882780985575) PC Desktop Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
