Question about Toshiba Satellite 5005-S504 Notebook
Does not try to book
I have a Toshiba Satellite 5005-S504 and it worked fine till this week. When I try to boot it, it does not even try to access the hard drive. Only the power, connected to power and CD indicators are lid in the front when I push the power button. I cannot open the CD drive.
It seems that the laptop is in some kind of weird mode.
This happend after my 21 month old daughter pushed enthusiastically the buttons on the front.
Is my laptop dead or does anybody have any idea how to make this thing work again?
  • doris418 Jan 08, 2009
    In my desperation to get this computer running again (against my best judgment I did not make a backup of this laptop in months) I force opened the CD drive with a paper clip and put a music CD in the drive to see what it does then. I tried the buttons in the front as I thought I might get the CD to play … nothing. I tried the power button and the computer booted. Why? I have no idea. As mysterious as it stopped working it started working again. I hope this will help someone else who has some strange things happen with their 5005. Good luck!
  • Anonymous Jan 25, 2009
    I am having the same problem. I removed the battery, plugged in the AC power cor, pressed the power button, screen still blank.
    Any other suggestions?
  • 93 Answers
Well friend, first that quite I recommend to you to remove the external battery and to try to use only the AC Adapter, in some occasions and when the Battery Pack becomes exhausted the equipment it tends to be blocked, reason for which I invite you that alone you try with the feeding source, in this case the equipment be able to operate without problem, then if everything is OK turn off and place again the battery packaging.
Posted on Jan 09, 2009
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Getting memory error on front display immediately on power up
It is surely indicating issue with the memory.
Can try to reseat the memory (remove from slot and reinsert again) make sure to wipe the contact with soft tissue.
If still facing issue then replace the memory.
Apr 30, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
My Toshiba 5005-s504 has motherboard problem.
Personally I would junk it those laptop models had bad overheating problems toshiba even lost a class action lawsuit over it.
Dec 19, 2008 | Toshiba Satellite 5005-S504 Notebook
Function keys dont work
Go BIOS and check if the FN key be disabled.
Nov 11, 2008 | Toshiba Satellite 5005-S504 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba 5005-S504 satelite
Check power adapter and your power cord. Your battery is not charging....
Mar 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
198 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
