Question about Spectra Logic Hello Kitty 13" TV
Blue screen-tv doesnt recognize dvd player
Kt2114 hello kitty pink television) doesnt recognize we no longer have dvd signal to tv.Dvd player is fine-works on other tvs.tv doesnt seem to recognize av signal.av1 & av2 are just blue screens.
  • Saffyrre Nov 25, 2007
    We're having the same problem. It worked just fine for months now suddenly the AV channels don't show the DVD player (while the DVD player works fine on other tv's). Have yet to find a solution online to it but many others that have had the same problem.
Hi Shuttle83,
Thank you so much for your reply!
We ended up switching TV's with my daughter so that she can still use her DVD player (we don't have cable set up in her room [only in our room], TV was strictly for DVD use!). We have the cable connected now that it's in our room but the only way it works with Cable is if we put a VCR in the middle of it. It won't go above channel 2 unless we connect it direct to the VCR and then change the channels that way. It's very strange!
We got the TV on sale at Wal-Mart last year for like $50 so not sure if it's worth us taking to a TV Repair place. We might just be stuck with it like this for now since it sounds like it's an internal problem.
Thanks again for your help, it is much appreciated!
Posted on Nov 25, 2007
    Genius:
  • 1,139 Answers
Hello crawf and Saffyrre,
I have seen this issue before, and I have good news and bad news. The good news is the problem is caused by an electronic bypass circuit, The circuit is between the AV derived from the RF input connector (for cable TV and off air TV) and the AV derived from the DVD player Audio Video input jacks. Hence the problem of being able to plug the DVD into other TVs and it works. Now my question to each of you is; Does the TV work on off air and or Cable TV.
This might range from a cold solder joint on the circuit board, to a component actually going bad. I would suggest taking the set to a qualified TV repair shop and getting an estimate. If the cost is right have it repaired, if the cost is not right replace the TV with a new one.
If you do decide to replace the TV could you both send the bad TVs, so as I could figure out what is causing this problem, design a fix for it and then provide an actual online solution to this problem because this is happening way to much for it not to be a systemic problem with all of these Hello Kitty TV sets.
Thank you both,
I hope this helps,
Shuttle83
  • Henry McKelvey
    Henry McKelvey Nov 27, 2007
    I agree that it would not be worth the cost to fix this unit.
    What you could do is use a modulator (Radio shack has these) and connect the DVD A/V jacks to it and the set the modulator for channel 3 and then turn the TV to channel 3 and connect a coax cable between the TV and the modulator. This will allow the DVD to be played through the modulator into the TV, you can also install a coaxial switch to switch between the DVD and the Antenna or cable connection (if used).
    I hope this helps,
    Thank you,
    Shuttle83
Dvd color mostly blue and pink, colors look weird
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Nov 05, 2007 | Konka KDL-37AT23U Television
Hello, the DVD play fine but tv mode, continually says no signal and screen is blue. Please help
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
Oct 27, 2014 | Akai LCT3201AD 32 in. LCD Television
SERVICE MANUAL KT2114
I doubt you will find it as this set is made by someone else with that name put on it; Hint: if you open it look for the name of the maker on the picture tube itself.
Dec 12, 2012 | Spectra Logic Hello Kitty 13" TV
I just finished watching a video and the screen now says "no signal" how do I return this to watch TV?
switch inputs. if you were watching a dvd and turned off the dvd player the tv will no longer be recieving a signal. turn the dvd player back on to test.
Mar 05, 2011 | Philips Magnavox 27MS343S 27" TV
Univseral Remote Code for SS213 TV
I don't think there is a Direct TV remote code for this type of television. (Strawberry Shortcake). I'm assuming the reason is because this is such a cheap, generic tv that Direct doesn't recognize it. "Strawberry Shortcake" isn't as big as "Hello Kitty" I guess.
. This is sad because even though the big, pink power button has popped off to where you have to press the little rubber nub, my daughter has been using hers for well over two years where many reviewers have given the tv model bad reviews of breaking down after only 6 months. Hers did not come with a DVD player, although it IS a SS213 model.
May 07, 2008 | Spectra SS213 TV
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
TV/DVD combo - no DVD function anymore
Hello sandiedog,
Tell you daughter, good catch the message she saw was initializing EEPROM (Electrically Erasable Programmable Read Only Memory)
This tells me that the computer that controls the DVD might have a problem. It's not that the TV can't switch to DVD its that the DVD is not working or is not able to work due to a memory issue.
The question becomes is this set worth the time that it will take to fix this issue (This is not a reset issue, this is a repair issue).
Here is my suggestion, Take the TV to a repair shop for an estimate (they are usually free, but make sure). Then decide if the cost of the repair is worth it, or if buying another one is the way to go.
I hope this helps and wish you well,
Thank you,
Shuttle83
Nov 25, 2007 | Spectra Logic Hello Kitty 13" TV
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Spectra Logic Hello Kitty 13" TV Logo
324 people viewed this question
Top Spectra Logic Televison & Video Experts
Marvin
Marvin
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
