Question about Canon Cameras
Dirt on the inside of the front lense
Hello, I have a efs 17-85 canon lens but there is a little bit f dirt on the inside of the front lens. Its fine when photographing most things but I am photographing snow and against that they are very visible. Is there a way of opening the lens up to clean?
thank you neville
Hello, I very much doubt that a small piece of dirt on the lens is a problem. It is more likely that your sensor needs to be cleaned. Sensor dirt is more visible at small (f11 to f32) apertures. I expect that you are shooting bright snow with a small aperture & this is why you are seeing the problem. To check, try the following.
Set camera to Av, ISO 100.
take some photos of the sky, a blank wall, or some other featureless surface, as follows:
1 - Set aperture to highest possible f - number.
2 - set aperture to lowest f-number.
3 - repeat 1 with a different lens
4 - repeat 2 with a different lens.
I expect that you will see photo 1 and photo 3 will have identical smudges of dirt on them. Photos 2 and 4 should have no smudges. If this is the case, your problem is dirt on the camera sensor. The only way to fix it is to clean your sensor.
Posted on Jan 08, 2009
Need to take apart Canon EF70-200 Lens to fix zoom component
Good luck. EF-s systems are a bit trickier to put BACK TOGETHER. Taking apart is the easy part! :)
Oct 25, 2013 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I cannot get my new 50mm/1.8 lens off of my Rebel XT. PLEASE help!
Make sure you're holding down the lens release button, which is located on the front of the camera, while turning the lens. Sometimes a little bit of force is needed, I've found new lens' can stick a little bit. If it still won't come off, contact Canon.
May 10, 2011 | Canon EF 50mm f/1.8 II Lens
Canon 24-105 lens. Manual focus ring is stuck, does not turn, auto focus works fine. Thanks, Mark
Place the lens on the palm of your hand and tap to see if any dirt comes off.Use a pressure air to blow into the gaps to see if the jam can be released off. If not your will need to open to clean and release.
Oct 01, 2010 | Canon 24-105mm f/4L IS USM EF Lens
Ol filme camera lenes fit mycanon ef-s digital eos 1000D
are your old film lenses FD or EF mounts ?
(Is the old film camera a Canon ?)
EF will fit EFS fine. My expeariance is with the EOS 3000 EF film camera (2002 -etc) and these work fine.
If you have Canon FD, there are some lens converters out there however I have not seen any yet which electrically connect and there is no AF. All Manual focus.
I have used Olympus OM mount adaptors with manual focus to mount older/different mount lenses with some success (As an example).
Best idea is to search ebay for your mount converters.
Feb 07, 2010 | Canon Cameras
Dear representative. My canon lens EF 24/70mm f/2.8 felt to the floor. As a result some white small plastics need to be replaced. Do you sell this parts?
This is the canon parts phone number 732-521-7230
Without knowing what the small plastic parts are or where on thelens they came from I cannot help. Parts may be able to get your the correct part
Nov 05, 2009 | Canon EF 24-70mm f/2.8L USM Lens
Scratched front lens element
Well, you cannot buy the front element by itself. The whole front optic set comes as a unit. You can call Canon USA, ask for parts,
1-800-828-4040
The part number you are inquiring on is: CY1-2800
Have you taking any pictures with the lens? usually it takes quite a bit of damage to effect images. The rear optics are the more sensitive glass on all lenses
Oct 03, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Cameras Logo
274 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
