Question about TallyGenicom 6312 Matrix Printer
Hammer voltage 2
This the message that come up when printing on tallygenicom6312. It print for about 2 min and stopped.
    Novelist:
  • 169 Answers
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
Replace the
Controller Board
Posted on Jun 22, 2009
Pro901 stopped printing in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
I have a taly t6215,for about 7 years it worked with no problem.but it's about 1 week that when we print it shows an error message like this:"...voltage".when I turn it off and then turn it on it work
You are most likely seeing "Hammer Voltage" errors on the T6215, it is worth observing the exact wording of the error seen as this can identify the cause. If the error is Hammer Voltage this indicates there is a problem with one of the following components; One of the hammer coils may be faulty, try a meter across each coil to measure its resistance a faulty coil should show up as being different to the majority. There may be a short circuit to one one the hammer coils, ensure the ribbon shield is not damaged and is in possition correctly, also ensure there are no foreign bodies which may short across the hammer bank. Check the ribbon cable from the main board to the hammer bank for damage and ensure the cable connects correctly. There may be a fault with the main board or with the interconnect board on the hammer bank.
Nov 12, 2011 | Tally T6215 Matrix Printer
Talley 6306 showing fault: hammer voltage 2
Hammer Voltage 2:
Solution:
Replace the Controller Board
May 04, 2011 | Tally T6218 Matrix Printer
I have a tally genicom 6312 printer which gives me hammer voltage 2 error what do i do
If no defective coils are found replace the Controller Board.
Dec 31, 2010 | Tally T6218 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Tally 6218 hammer voltage 2
Hammer Voltage 2 is the worst error you can get on the Tally T6200 series...
Explanation:
hammer coils.
bank temperature. Check blower underneath ribbon Deck.
Corrective Action:
Check the hammer bank for defective hammer coils qty 7 per hammerbank.
Aug 25, 2009 | Tally T6218 Matrix Printer
I have T6218 printer and it prints for about TWO minutes then starts slowing down and then stops printing showing an error of "HAMMER VOLTAGE 2". I relaced the Hammer coil kit in Banks 1 and 2. still same...
If you haven't fixed? If you don't get Hammer Voltage 2 error immediately, then sounds like your blower underneath the ribbon deck which keeps the hammerbank kewl is not working... Be careful but you can get shelf or cart about printer height and remove the ribbon deck with ribbon & cables still connected from the print. Rotate and sit it on the shelf or a cart. Start printing and see if the black blower(in the middle with a little black air duct going to the hammerbank) is working.
One other thing their's qty 7 hammer coils per hammer bank, if you have replaced the 1st 2 reading from left to right with hammerbank installed in printer, then you have qty 5 more which 1 of the 5 left is causing Hammer Voltage 2.
Have any other ??? feel free to call at x311
Toby
Feb 02, 2009 | Tally T6218 Matrix Printer
HUMMER VOLTAGE ERROR
There are two different Hammer Voltage errors on the 6306; Hammer Voltage 1 and Hammer Voltage 2.
Hammer Voltage 1:
One of the hammer drive circuits was turned on when it shouldn’t have been, so all printing has been disabled. The usual cause is a failed drive transistor.
Solution: Replace the Controller Board.
Hammer Voltage 2:
Solution:
May 07, 2008 | TallyGenicom 6306 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
206 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
