Question about TruTech PLV16190 Television
Trutech 16190 Wall mounting
I want to hang my Tv on the wall, but lost the screws. I can't find a screw that fits the holes on the back of the TV set. Does anyone know the correct size of the screw that I should use, and correct thread too?
    Scholar:
  • 73 Answers
They are usually designated in Metric sized screws.
Find the closest standard screw to your size, and go into home depot and ask for some help finding the metric. Get the closest to and one above and below, since they should be 15c each and through process of elimination, you will find it. The length should be no longer than 1 inch.
Unfortunately that is all the info I can give you as there is no cut sheets or manuals to refer to. This brand is a Target brand that they have had multiple manufacturers make.
Please see this link for some interesting info about this.
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Posted on Jan 09, 2009
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
What size screws are required for wall mount on tv ?
I did not find that listed in the owners manual, you will need to contact the manufacturer as to the mfr recommendation of proper mounting screws.
Oct 16, 2014 | Mintek DTV-265-D 26 in. LCD TV
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | Toshiba 47TL515U 47 3D LCD TV
Need 4 screws for phillips 42pf9946-12 plasma tv to fit wall bracket
Best way to be sure is call Philips customer service with the model number to get the thread type and length of these--no two sets are the same here---usually most will be available at local hardware stores if Phillips does not sell them(that would be a bit more pricey and take time).
Jun 15, 2012 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
Jul 01, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
How to mount a conia CL3201HDR on the wall, no screws in box and not sure what thread size to purchase.
You need to purchase the wall mount separately. They range from a simple "on the wall" mount to swivels and extending mounts, and can be very expensive for the fancy features.
First, make sure your set is wall mountable. In the center of the rear of the set there will be a square arrangement of bolt holes. I do not know of any newer sets without them, but it does not cost anything to take a look and make sure.
Next, you need to decide on a mount. Personally, I did not want to spend allot, so I found a very inexpensive, yet good quality, "straight" mount at Sears for around $25.00. It does not extend or swivel, but all I wanted was to get it on the wall. Different screws and bolts were supplied with it and I was able to match up what worked for the back of my set.
Now, THE MOST IMPORTANT PART!!!!!
You ABSOLUTELY MUST find where your wall studs are! This is CRITICAL! DO NOT use any kind of expanding bolt to mount your set or it will eventually come loose and FALL!
I had an inexpensive "stud finder" (around $10-15) to show me where the wall studs are... Sears sells them too....You want to bolt your TV wall mount to the studs using 1/4" stud or lag bolts (they look like oversized wood screws) for maximum strength, if your mount will accept bolts that thick. Also use flat washers on the bolts. If your TV mount has its mounting bolt holes too wide apart for bolting to a standard 2" wide stud, mount a 6X6" piece of 1/2 plywood through your wall to the stud, using at least 4 #10 deck screws...it may be overkill, but it will be secure... my personal saying is, "If I can't hang from it, neither can my TV!" This is critical if you want to use a fancy swiveling mount that extends out since it will add stress to where you bolt it to the wall.
My mount was in two pieces.... a section that bolted to my wall, after I mounted a piece of plywood as I described above. This piece has a large pin that sticks up, and the part that mounts to my set (with the screws provided by the manufacturer of the mount) has a receiving hole that slides over the pin. When I need to take my set down, I simply lift it straight up.
I hope my long-winded solution did not bore you, and I wish you the best in hanging your set. Please take a minute and rate my solution.
VA
Jan 30, 2011 | Televison & Video
I have a Samsung B2330HD TV with universal wall mount. The screws with the wall mount do not match the hole size on the tv. It seems as though this is a common problem. Any idea what the screw size I...
I'm told you have to force the M4 screws to fit. This is a computer monitor with a TV Tuner not a TV with a computer input. It was not designed for wall mounting.
Nov 04, 2010 | Samsung Televison & Video
Took 6 screws out of back of stand on my Olevia TV, but still can't remove stand so I can hang TV on wall
I just wrestled with this problem. The screws were backed all the way out but I could not remove the stand. I had to remove the screws completely from the holes, then the stand can be pulled down then off.
Oct 19, 2010 | Olevia LT32HVM 32 in. LCD Television
TruTech PLV16190 Television Logo
149 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
