Question about SanDisk Sansa e250 MP3 Player
Gray Screen Hello- Need help please. When I turn on my Sansa I get the Sandisk logo, then after about 10 seconds it goes all gray and no functions work. I can hold the menu for 20 seconds to reset, but I can't get the unit to work properly. If I plug into my computer, the unit turns on but the same thing happens all over again. Any help would be appreciated. Chris
That worked. Thanks for the help!!
Posted on Jun 02, 2007
I had a very similar problem where my Sansa would turn on show the initial logo then fade to a white/grey screen and restart. To fix it started in recovery mode (Start in hold mode with rec button held down) then used the firmware updater to update the software and it seems to had fixed the problem hope this also works for you
Big gray spot on screen
Unfortunately, It's likely that your screen has been irreparably damaged. Probably, pressure was applied to the screen and ruined that part of it.
If you like to fix electronics, it may be possible to buy a non-working Sansa on eBay, open the case and replace the screen.
You can probably continue to use the player without fixing the gray spot. If it bothers you, the easiest solution would be to get another player....
Dec 03, 2011 | SanDisk Sansa Audio Players & Recorders
The screen of my sanza fuze turned gray
this happens... with mine a ton, i want to get a new one to get a fresh start so maybe it won't happen as often... but give it a rest or something and it will eventually start working. my problem is that the screen blacked out and it's not playing music.NVM O MY GOSH IT JUST STARTED WORKING. WOW. so i don't have a problem. yay. wow, is that ironic or what?
Mar 23, 2009 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa Express MP3 player stays at SanDisk logo
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Jan 01, 2009 | SanDisk Sansa MP3 Player
Sandisk Sansa goes to blank screen. No display and not working
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa wont turn on :(
Try taking it back or calling the company where you got it from.Unless of course you got it off of ebay then contact the seller.
Mar 15, 2008 | SanDisk Sansa e270 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
My screen is messing up
Hi hope this helps. Turn off your e260. Slide the hold switch for it to show red/orange color. Then press the record button and the menu button until you see on the screen of the player "Welcome to Recovery Mode". Now go to the sandisk website and download the firmware update if you have not tried to update the firmware of the player. Run and install it on your computer, when it ask you to connect a device hook your player to the computer and then it will try to look for updates for the player. When it does update the firmware of the player. And also if you can get to the menus of the player you may want to format the player maybe it is your songs causing the problem. Switch the player to MSC then open My Computer and format your player on that window.
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
When turning on screen fades away then restarts automatically
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
