WHIRLPOOL AWO/D 5726 - cold water feed only?
Am just about to have a new washing machine (as above) delivered and just wondered if this has hot and cold feed or cold only.
Thanks
  • Washing Mach... Master
  • 3,463 Answers
Most washers now made in the u/k, are cold fill only, but if the new washer is hot and cold fill, and you only have a cold supply, then it will tell you in the installation guide how to connect it to use it from cold only.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
Modle AWO 9561 In the second cycle the machine shows F&H error in the display, machine will not carry on. Even when switching off, same error appears.
Whirlpool's 'FH' stands for 'no water inlet'. Presumably the second cycle is rinsing (?) and that requires cold water as opposed to hot for the first (wash) cycle.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 17, 2011 | Whirlpool Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT PUSH THE WATER THE OUTSIDE OF IT
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT pullTHE WATER THE inSIDE OF IT
Feb 08, 2011 | Whirlpool Washing Machines
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Gushing water - Hoover SPB11 washing machine
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
Dec 06, 2007 | Washing Machines
Washing Machines Logo
287 people viewed this question
Top Washing Machines Experts
