Screaming crackling noise when very hot
When the amp has been used for a few hours it starts makeing a screaming crackling noise but still works, even with all the volumes turn off, it still makes the noise, could this be a valve? if so how do i tell which one.
  • 2,071 Answers
Crakling sound is a symptom of loose or cold solder in amplifier section where the STK IC or Darlington transistor is located .You better re solder all parts joints there in order the crackling sound is gone.
Hope it may help you;
Regards;
VOTIT
DON'T FORGET TO RATE;
Posted on Jan 08, 2009
Noise from a Yamaha EMX 2000 Powered mixer
Sounds like it might not be cleaned enough. They may have done the pots but the internal circuit boards may not have been done enough.
May 11, 2016 | Yamaha Music
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
My Paradigm PDR 12 subwoofer has started to make crackling noises. Is this an amplifier malfunction?
Depends when it makes these crackling noises.
If it's when the sub isn't being driven, then it could be the amp. (Check for bulging capacitors on the amp board). If it's when you move cables about then it could be a broken lead or a dry solder joint on one of the inputs.
If the crackling is when the sub is running then it might be the voice coil has distorted due to being overdriven with a poor and highly distorted signal.
Sep 07, 2014 | Audio Players & Recorders
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Whining and crackling noise
it might be or there could even be a loose wire in there somewhere. did you install everything yourself?
Apr 14, 2009 | Car Audio & Video
Pioneer deh p7500mp
definitely a heat problem. There is a chip (or set of chips, perhaps audio output chips) that work fine when cool, but when they are hot they start to fail. Common problem with IC's. Heat is not a friend of these devices. Time to get it repaired or get a new one, depending on cost of course. Also, do you have an amp attached? Perhaps the amp is the device with the failing IC's.
Aug 09, 2006 | Pioneer DEH-P7500MP CD Player
239 people viewed this question
 Grubhead
Grubhead
