Question about Kenmore 42161 / 42169 Electric Single Oven
Oven won't unlock!
I came home from work - reset the clock on my oven and noticed it was locked. It won't unlock and I've tried every button. I've just moved in this house and can't find the manual. It also sounds like it's cleaning or something, but every time I hold down cancel, F7 flashes up. I've done internet searches and just can't figure it out. The clock is set, but the lock light just won't shut and release the door. Help!
  • 1 more comment
  • cardioman8 Nov 19, 2008
    oven won't unlock
  • hehaak519 Apr 10, 2009
    I have a Kenmore wall oven (built-in) which wont unlock
  • Anonymous Mar 25, 2014
    says ive gotta log in to google to unlock but it refuses my email too. she put a pattern on it but nothin i do unlocks it. even after resetting reset button. who makes or works on zoidpads
  • 883 Answers
Find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
Posted on Jun 01, 2007
SOURCE:
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven 790 model number, door locked, won't open
do you have a button with a small padlock symbol?
yes hold for 10 seconds
no..do you have start button? press and hold for 5 seconds
no...how about a clear/off press and hold for a full 3 seconds.
Sorry I'm at home and the teck guides are not here. So I gave it what I know from memory.
last but not least try turning off the breaker to it for a minute.
Hope this helps a little.
Feb 02, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    What does the sign "control lock" mean?
    Here is what the manual for your oven says about control lock.
    Let me know if you have questions.
    Control Lock
    unintended use of the oven(s). The Control Lock will remain set
    after a power failure, if set before the power failure. The only time
    it is not available is during the Sabbath Mode or Self-Clean cycle.
    When the control is locked, only the TIMER SET · START, TIMER
    CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
    CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
    function. On double oven models, CLOCK SET · START will also
    function.
    To Lock/Unlock Control: Press and hold CONTROL LOCK for
    about 3 seconds, until “CONTROL LOCK” and a picture of a lock
    appear on the display. Repeat to unlock and remove “CONTROL
    LOCK” from the display.
    May 13, 2010 | KitchenAid SGL OVEN T/C
    Oven lock light
    Oven lock is usually associated with oven cleaning. Last owner probably tried to clean the oven for you and didn't finish the cycle. Either finish cycle or turn it off (if possible).
    Oct 03, 2017 | Maytag MEW5530D Electric Single Oven
    Whirlpool oven accubake system
    I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
    Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
    Door Keeps Locking and Unlocking after Power Outage
    Located the switch - resetting fixed my stove as well.
    Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
    Kenmore 42161 / 42169 Electric Single Oven Logo
    233 people viewed this question
    Top Kenmore Ovens Experts
    Archie Ferrarini
    Archie Ferrarini
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
