Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Linksys WUSB54GC Connected to the Network But No Internet
I've been using the Lynksys WUSB54GC to my Linksys WRT54G2 wireless router for the past few months without any problem. However, recently my PC was 'attacked' by the 'Antivirus 2009' and 'ieMonster.b' malware. I used Malwarebytes' AntiMalware to kill the malware. Ever since then my PC has been having the problem of "connected to the network but internet cannot be found". My other 2 Acer laptops work just fine, so is my main PC. I've tried to "repair" connection, use cmd to renew ip address, reinstall internet drivers but to no avail...Could someone please help?? Linksys support provides no help at all!!
  • 1 more comment
  • pglaksa Jan 10, 2009
    Finally got this problem fixed. It's caused by an error in "sock2". Downloaded a freeware called "ispfix" and managed to repair the wrong values in sock2 that was caused by the removal of "Antivirus 2009" & iemonster.b" malwares. Thanks.
  • pglaksa Jan 11, 2009
    Sorry, typo - it should be "lspfix" and you can get it from the following website www.cexx.org/lspfix.htm
    Hope this help
  • jesusbell_li May 11, 2010
    where can I find the ispfix?
    Problem Solver:
  • 7 Answers
I got me a Linksys and had the same problem, if solved this bij flashing the router with a new firmware.. and now it okee for a long long time..
Do you know how to do this?
let me know
Gr Rich
Posted on Jan 08, 2009
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
I have a lynksys router. It will work with our mac, but if i try to get online with my pc, neiter will connect or if one is connected, it will disconnect. can i fix this
I see that you are having issues with your network connection, I believe that you are trying to connect wireless on both systems.
* Check your Linksys for settings that limit the routers wireless connection, most wireless routers have an option on how many computers can connect wireless to the router, a wireless signal does not chose what OS to allow for a wireless connection.
* get in your Linksys Routers Setting page from IE or Firefox using your Default gateway IP from there on you can check your Routers settings, user name depends if your internet service provider changed the Routers user name and password but for a Linksys try admin / password or admin / admin for the User name and Password field.
Hope this helps you thanks and have a good day.
Mar 30, 2011 | Cisco Lynksys Dual Band Wireless N Gigabit...
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
I just bought a WUSB54GC v3 adapter and went through the setup. Everything said it was successful and was able to connect to the network. When I opened an IE browser, it said page cannot be displayed. I...
check the IP address on your computer. There might be a static IP address on the computer. You said that your other computer is online wireless. Open the router set up page and check the wireless settigns of the router.
Click Here to know more about the routers and network
Jan 19, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
I have a Lynksys Wireless-G brand WRT54G2 router connected to my High Speed Ethernet Modem and to my desktop computer. It puts out a fairly decent signal to my laptop across the house through walls and...
Yes. 1. Disable the DHCP in the belkin router. 2. Take the cable from the LAN port of the Linksys router to the LAN port of the Belkin Router. 3. Dont touch anything else in any of the routers.
This should help
Thanks Ranjit
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Nov 15, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
WUSB54GC model wireless adapter won't connect after months of use
Instead of using the passphrase use the wep key 1 that you created on the router page when you generate it using the passphrase.
Then when you try to connect using the linksys wireless monitor just leave the passphrase blank and type in the wep key1 box the key that I mentioned earlier.
May 17, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
667 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
