Question about Olympus FE-190 Digital Camera
CARD set up PROBLEM
After powering up camera card set up appears which gives option of power off or format. Choosing format will erase all detail? Why is this apppearing on power up and how can rectify?
  • jojo100000 Feb 23, 2009
    i can not to format xd card
    Genius:
  • 1,011 Answers
Dear,
at the time of this indication, what is the status of the card,
is it full or having empty space.
if its full then dont get and save alot of pics so that the memory fulls.
sometimes, this kind of problem occurs due to overloading of card,
if not,
then u have to reset the settings of your camera.
do it plz
regards,
Posted on Jan 08, 2009
When the CF card is loaded it says no memory.
Hello jesser..... Remove the card and look around the edge of the card for the wee lock. Open the lock. Reinsert the card. Turn on the camera and go into the menu. Find the format function. When you format the card it will erase any photos that are currently on the card and set it up to be used in your camera. Joe
Thanks for choosing Fixya!
Dec 29, 2010 | Nikon Coolpix 5000 Digital Camera
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
Why My kodak dc280 can not read the memory card?
Try formatting your camera memory card If you own camera memory cards that have been used in other digital cameras, the card may not be properly formatted for use in your camera, or that data on the card may become corrupted. When these issues arise, your camera indicates that the camera memory card needs to be formatted.
When you format a camera memory card, all of the information on the card is erased. This includes any borders supplied on the card.
  1. Set the Mode dial to Camera Setup.
  2. Slide the POWER switch to the right to turn on the camera. The main Camera Setup screen appears.
  3. Press a updown_icon.gif button until the format_icon.gif icon is highlighted. format.gif
  4. Press the DO-IT button. The Format Memory Card screen appears.
  5. Press a updown_icon.gif button until CONTINUE FORMAT is highlighted.
  6. Press the DO-IT button to format the camera memory card and return to the main Camera Setup screen.
Dec 10, 2009 | Kodak DC280 Zoom Digital Camera
When power is turned on the card setup screen pops up. The only 2 options are to power off or format. If I select format, the pictures will be erased if yes is selected.
Memory card seems imbalanced due to some reason and can only be corrected by formatting as advised in camera pop up.
Of course all picture files will be deleted if card is formatted. Try to put card in card reader and back up files in computer.
Sep 11, 2009 | Olympus FE-230 Digital Camera
Card error
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering images.
Feb 12, 2009 | Olympus FE-170 Digital Camera
Olympus c150 camera put new memory card in getting message card set up format power off then mesage erasing all help please i have a C-170 camera, when I turn it on, 2 options are given power off and...
The problem is that the largest xD card that your camera can support is a 256mb card. The M or H 256mb cards are not compatible. The firmware in the camera cannot support memory storage of that type. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Feb 11, 2009 | Olympus FE-170 Digital Camera
Can't take photos
Using a USB SD card-reader, copy all the photos from your camera SD-card to your PC, then try format option in your camera, this way the photos in your SD card are safe(in the computer). OR
insert a new/empty SD card into your camera. Use the format option and start clicking photos.
Dec 17, 2008 | Olympus Camedia C-350 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Memory card format.
The Polaroid PDC 700 digital camera accommodates an optional, Type 1 ATA compatible CompactFlash memory card up to 48MB. When an unformatted memory card is installed in the camera, it is automatically formatted when the camera is powered on. WARNING: Once you format the flash memory or format a memory card, all images are erased and cannot be retrieved - they are gone forever! Before you format (erase) the flash memory or format a memory card, transfer the images to your computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Olympus FE-190 Digital Camera Logo
46 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
