Stuck filter in a Bosch Maxx WFL 2450
Hi there, Hope you can help. We have a Bosch washing machine, which had a new pump fitted a year or so ago. The machine is about 5 years old now. I used to remove the filter at the front of the machine and clean it. After it was fixed, the filter was placed back in the machine so tightly I could not twist the part at all manually. I used a spanner and the cross piece at the front disintergrated. Any suggestions in how to remove it? Will I have to cut it out somehow? I have a new part on the way here. Appreciate your time. Toby Walker
  • Washing Mach... Master
  • 3,463 Answers
You have to get the filter out by any means possible, what I would suggest is that if there is any part of the filter left to get a grip of, then use a strong pair of pliers or grips, and grasp what is left of the filter cover, and try and twist and pull at the same time.
Or try and lever it out with a screwdriver or similar. one way or another, it nshould come out
If all else fails, then drill a hole in the center of cover
and leverit out that way.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Maxx WFL 2450 Washing machine Electric fault
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
