You can use the Fn+F3 Keys to decrease and Fn+F4 Keys to increase the Volume. If the Audio is not working after increasing the Volume using the Function Keys, please try re-installing the Audio Driver in the Computer to fix this issue.
Please download the file, double click on it to begin the installation and follow the onscreen instructions to complete the installation. After installing the Audio Driver, please restart the Computer for the settings to take the effect.
This should fix the issue.
Good Luck!
Please post back if you require further assistance.
It must be a Volume device drive problem,please try to update your volume device drive software,find your original dell Inspiron 1420 volume device driver software or download it from www.dell.com
Step 1
From the Task bar located at the bottom of your computer click once on the "Volume" icon.
Step 2
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Step 3
Right click on the "Volume" icon.
Step 4
Select "Open Volume Control."
Step 5
Uncheck
all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep
selections. If this does not resolve your sound issue, proceed to step
6.
Step 6
Right click on the "Volume Control" icon.
Step 7
Select "Sounds and Audio Devices Properties."
Step 8
Under the "Volume" tab, slide the "Device Volume" indicator to High.
Step 9
Under the "Speaker Settings," click on "Speaker Volume."
Step 10
Slide the "Left" and "Right" volume indicators to "High."
Step 11
Click "OK." If this does not fix your sound issue, proceed to step 12.
Step 12
Step 13
Step 14
Go to the "Hardware" tab and select the "Driver" tab.
Step 15
Make sure you are connected to the Internet and then, Click on "Update Driver."
Step 16
After the driver has been updated, Click "OK."
1st check your PC if audio is fine with headphones or some other speakers , then check your control panel and test sounds compatibility might that you are using wrong speaker setting in the PC. The below is the company web link to your speaker set , try this too http://www.polkaudio.com/homeaudio/specs/recent/amr50/
if nothing works please msg me the exact config of ur PC
look for advance settings into the sound driver ..you also try on the volume icon ...propieties...check the mute case ...the volume ......from advance settings boots it ...but it might be also not comp. with linux
no sound
