Question about Philips Magnavox MS2530C 25" TV
Great Sound and Menu Option, But Black Screen
Dear Support - I was recently given an older Magnavox TV Model TS2560 and the sound and menu button work great, but the picture is completely black. Even when I disconnect it from the cable outlet and just have it plugged in, I hear the "snow sound" but it's still black. Any suggestions and thanks for your expert advice. Robin
4 Suggested Answers
  • 55 Answers
SOURCE: screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Posted on Mar 22, 2008
ladywinn
  • 5138 Answers
SOURCE: 27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
Posted on Jun 25, 2008
villamore
  • 27 Answers
SOURCE: philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Posted on Jul 31, 2009
How do I fix LG42cs560, I have black screen, vertical lines and no sound?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2015 | Televison & Video
My magnavox tv changes from green to red to blue and stuff and i get no picture or sound on it what is wrong with it? and is there something i can do to fix it?
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 11, 2015 | Magnavox Televison & Video
Magnavox model # FP4630 W104 manual
GOOGLE THE MODEL NUMBER WITH MANUAL AFTER IT IF YOU NEED THAT.
In the TV menu make sure under audio speakers are switched on.
When you try to change the volume do you get a display on screen?
If the vol buttons on set work the issue is with the remote itself.
Let me know as much as you can so I can help
Mar 16, 2012 | Televison & Video
1995 Magnavox tv (model TS2560) Horizontal control WACKY
No, it is most certainly not worth fixing. In fact, it is worth nothing - even if it were working great. Probable cause: an obsolete electrical component. Cost: no TV tech will touch it. Sorry. Suck it up and buy yourself a moderately priced TV.
Jul 28, 2017 | Philips Televison & Video
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
When i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Jul 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Black screen covering most of tv screen at a few channels; a code appears at upper left corner. The black screen disapears for a few seconds if I turn the volume up or down at the remote control but it...
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
May 24, 2008 | Philips Magnavox MS2530C 25" TV
Philips Magnavox MS2530C 25" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
