My prnta iz epson r270 it asked for servise and i did using ssc but it is still blikng red, i suspect its with replacement of ink pad but i donk kno whow to find and replace, plz help
    Sergeant:
  • 287 Answers
MY GUESS FROM WHAT YOUR SAYING HERE IS THAT YOU NEED TO REMOVE THE PRINTER DRIVERS. IN ADD REMOVE IN CONTROL PANEL. THEN REINSTALL DRIVERS WITH THE DISK THAT CAME WITH THE PRINTER. THIS SHOULD GET RID OF THE PROBLEM. HAPPY NEW YEAR.
Posted on Jan 08, 2009
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
General error and flash alternately to the color red button in the ink and paper for Epson r270
The waste pad of your printer is already full..solution for that replace the waste pad and reset the counter of the printer..
Oct 26, 2010 | Epson Stylus R290 InkJet Printer
Need to replace ink pads for epson stylus rx620.printer. Where to buy and how to replace?
You don't need to buy the pad. Just wash with hot water. Is there a message to replace waste ink pad?. You need to reset waste ink counter. Use SSC utility to reset it. Extend outlet pipe to outside. You don't need clean pad again. If you wish to wash or replace pad, you must open case and diasemble all mechanics. Find SSC at indoreset.blogspot.com. And printer diagram at printersiam.com
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Epson r265 what does 2 red lights flashing slowley mean
It means that the ink counter needs resetting and the waste inkpad changing/cleaned. The Epson website will give you the address of a local service centre. Before paying out for that you could see if the SSC Service Utility would work for you although the R265 is not specifically listed as supported it is similar to the R270 which is. The free download is available here http://www.ssclg.com/epsone.shtml
Jun 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
2 red lites blinking no epson c88 printer
If both lights are flashing, it may mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can check this and restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type, then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If none of this stops the two red lights flashing, you will need to have a technician check your printer - it may well mean the main board has failed.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 22, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Not works
You can reset the waste ink counter using
http://tricks-collections.com/2008/09/resetter-epson-c58-c67-c79-c90-r270-r390-rx650-cx3900/
The generic SSC utility is also available at
However, remember ink is still accumulating in the waste ink reservoir and will eventually start to leak out. To replace the waste ink pads you need to disassemble the printer.
A free copy of the service manual is available at
http://www.filestube.com/2572254e26edfe0a03e9/details.html
Jan 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
51 people viewed this question
jasbo
jasbo
