Question about Zebra TLP 2844-Z Thermal Label Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
After installation it works well with its Software Zebra Designer Pro but when I send the command from any text editor it does not work. Actually I need to print Barcode from my VB6 application.
Will somebody send me a sample code write in EPL1 or EPL
  • 155 Answers
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Posted on Mar 16, 2009
    Problem Solver:
  • 17 Answers
This is the sample EPL command.. There are 2 language used by zebra EPL and ZPL u can identify what language has your printer just look under the printer...
D8 S2 ZT JF I8,1
FK"FIXEDAT0" FS"FIXEDAT0" Q35,0 q719 B135,80,0,1,4,12,135,B,"Barcode" A14,290,0,4,2,3,N,"sample text" A406,303,0,4,1,2,N,"Sample Variable" FE
Posted on Mar 20, 2009
  • msaa60
    msaa60 Dec 23, 2012
    what if i want to connect TLP2844 printer to a weight scale directly and i want to print a weight label can you send me the suitable command and also how i can downlode it into the printer
2 Suggested Answers
  • 105 Answers
SOURCE: I have Thermal Zebra Printer TLP2824, I have installed it and
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
Posted on May 27, 2009
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
This printer is no support with create-a-label
If you are using CAL (Create A Label) you must have a device called a "Dongle" plugged into your parallel (or USB) port. This acts as the activation key for CAL. If there is no dongle then CAL only works in demo mode. That's why printer Icon stays grayed out. The "Dongle" normally plugs directly into the parallel port and one end of the parallel lead plugs into the "Dongle" while the other plugs into your printer.
I would suggest that you download "Zebra Designer" software from the Zebra Website..This will work without any activation.
If you use ZD you must use the correct ZDesigner driver. (Install automatically as part of ZD setup) This driver only works with ZD.
If you need to link to a database then you will have to BUY label software. Zebra Designer Pro, or Nicelabel, or Bartender....etc.
Jan 10, 2011 | Zebra LP 2844 Thermal Printer
During install of Zebra Design Pro v2 on Winddows XP Proffesional V2002 SP 3 get "Exception EAccessViolation in module nbars.dll at 00099DD0. Access violation at address 008C9DD0 in module 'nbars.dll'....
I had the same exact problem, here is the fix:
1. Switch to Windows XP's Classic view in the Control Panel to turn off Themes. try using/installing the software
2. If this does not work, stop the Windows 'Themes' service. Then try the software again.
Sep 23, 2010 | Zebra Designer Pro for PC
Zebra Designer Pro Key
Zebra Designer PRO is an additional charge that must be purchased separately.
Mar 06, 2010 | Zebra LP 2844 Thermal Printer
Got a Zebra 160S thermal printer with no software disk. It was lost in a move. Where can I find one?
Download printer driver from Zebra website, also download Zebra Designer label design software (Free). If you just need the windows printer driver best to download from seagull scientific site. Their drivers work better than zebra's one.
Nov 13, 2009 | Zebra S Series 160S Thermal Printer
DO I need the software for the zebra eltron lp2443 printer pluse the driver
The only software you need for the LP2443 is the driver from
Install this driver, then you can use any windows application that uses win drivers.
Or you can download Zebra designer software to design labels from
Nov 11, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
We are transferring our data files to a new pc and will like to know whether we need to install a software to work with our TLP2742. If so, is there an online downloadable software?
You can download the correct driver for this printer for all Windows Operating Systems from the following Zebra Support link
Select the Zebra Universal Driver v5.5.7.25 as the printer driver. This covers around 50 different models but includes the TLP2742.
You can also download the designer and setup software as they should also work with the TLP2742
Oct 09, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra S4M printer and it has always printed fine. I downloaded Zebradesigner software to be able to create a label, but i am having trouble setting up the printer through the Zebra Designer...
you need to load the zdesigner driver from the zebra website, the older zebra universial wont work with zebra designer that why you can't pick it. Designer Driver (32 bit/64 bit, Windows Certified) &dvar3=50
Cut and paste the whole link and paste into the address bar of your web browser or just goto and click drivers and downloads.
Jul 08, 2009 | Zebra Designer Pro for PC
Zebra TLP 2844-Z Thermal Label Printer Logo
2,174 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
