Computer Does not Boot correctly, Monitor is Black.
I've been trying to figure this one out for awhile now.
Ok here is the issue.
We are trying to get the computer to boot up, at least into Bios, but there is no Display(Monitor is black), Keyboard seems to have activity but unable to use(Numlock lock, cap lock etc does not work, but I Know that the motherboard knows It's there because when I unplug and plug the PC back in all three lights on the Keyboard flash once(The Numb Lock, Cap Lock and Scroll Lock lights).
Also, I Used a wireless Keyboard and the lights on it comes on, and every time I hit a key It's action light flashes(Which is normal). The Display does not come on at all, We tried the onboard video, A PCI-E Card and a PCI Card, nothing.
The DVD Drive seems to work, Hard Drive works, Mouse and Keyboard seems to work, at lease they get power, All fans work, all lights work, I Tried another monitor(same problem).
The Computer does one short beep. but that means nothing, I Took out the memory, unhooked the Harddrive and still it does one short beep.
I Resetted the bios by removing the Motherboard Jumper and placing it back on, I Tried a different battery, no Luck.
IT Doesn't seem like it's the motherboard, The only thing we can think of is not enough power?
We rechecked everything, everything seems ok.
Could a Bootup disk solve this Issue?
Thank you.
laxman, that's not really a solution?
In any case, it can't be an OS problem if this issue occurs during BIOS load.
From the time the power button is hit, there seems to be nothing going through to Video and Keyboard.
I've found this to be an intermittent problem, but almost always occuring after a crash like power failure etc.
This stinks of motherboard problems, but it would be interesting to see if anybody here manages to replace their motherboard(pref same model) to see if the problem still occurs.
I thought it might be gfx card as well, but it can't be, especially if it occurs whether you use onboard or periph.
any help welcome.
  • 4 more comments
  • DominiqueZA Jan 08, 2009
    very tricky, keyboard not detecting durng boot up, will find a ps/2 keyboard and try resetting bios. - will let you know
    also beginning to wonder if there's any stock in the mentionings about not enough power being available for peripherals during boot up...
  • DominiqueZA Jan 11, 2009
    I've gone and reset the BIOS in the meantime, bootup seems fine.
    I don't get any beeps during boot up, haven't for a looooong while come to think of it.
    I'll be monitoring things to see if the problem is still there, since it can't really be reproduced at this point.
    cables all look fine, pins all in place.
    gfx card is dual, and both plugin points look fine(worth noting that problem occured no matter which one i use)
    as i said, all i can do is wait to see if the problem has gone away, although this isn't really the way i like to solve problems. Best to know what the problem was to avoid in future.
  • Anonymous Jan 31, 2009
    I have been having an issue where my computer won't boot for the past month now. Got it up and running a couple of times and now just found that if my monitors are not powered on the computer boots right every time, if monitors are powered on computer gets stuck before loading windows. Also when monitors are on I couldn't boot from a floppy or CD. I think it could be a problem with the graphics card, but not sure. Any thoughts?
  • Axekick May 11, 2010
    I would be inclined to think it is your monitor cable but there is very little to go on and I am no expert.
    *Does it sound as if the computer's hard drive is fully booting to your operating system or not?
    * I think if your PSU is too small your computer will usually shut itself down rather than just failing to power any one specific thing.
    * When you tried the other monitor did your also try another monitor cable?
    * One short beep usually means it passed the initial diagnostic
    * Often you need to change your BIOS to change between PCI -PCI-E & AGP video modes so unless you are familiar with this BIOS you may not have yet eliminated the possibility of the video card.
    Again based on the information provided I would tend to think it is the monitor cable. Have you tested the monitor and cable on another system?
    I would recommend you open the case and disconnect everything, reseat the memory, remove the motherboard battery(again) then ensure all connections are clean and reconnect everything.
  • Kevin Nelson May 11, 2010
    What type of monitor are you using, crt or lcd? Have you tried using a spare monitor to see if there is a any video getting through?
  • Mark Robinson May 11, 2010
    have you tried resetting the bios ?
    Novelist:
    Scholar:
  • 70 Answers
Very interesting...Might try the following...
- Video. Yes, almost garuntee that it is either the video card/onboard or the cable. Look at the cable and cable connectors and see if one of the pins has been shoved in. This is common. Often, one will replace the cable and still have the problem because a pin has been shoved in on the mother board.
- Power. Remove everything from your computer except the keyboard and the monitor (yes, even the mouse) to eliminate any power drain issues. If you can, remove the DVD drive (unplug power and data bus cable).
- BIOS. One beep is good. You should be able to get into the BIOS setup no mater what other problems you are having. The BIOS uses a generic text, video and keyboard driver. If you aren't able to see ANYTHING after the beep then it is definately the route from the motherboard through the video card or onboard video, through the cable to the screen. You seem to be going through the right steps to debug but just haven't found it yet because it is something that you have dismissed as working...like the pins on the video connector. Go through your path again, this time look at anything that you have assumed that was working and suspect it as the issue.
Posted on Jan 08, 2009
3 Suggested Answers
laxmankumar
  • 191 Answers
SOURCE: Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Posted on Sep 27, 2008
  • 7 Answers
Hmm it seems to be problem with Power Supply, but still if you can give a try connecting your system into other socket may be which is properly grounded one.
if the above didn't fix your issue, i would suggest you to disassemble and then assemble it again. try changing the data cable as well..  Last option left is if you have a spare SMTP checkout with that.
Let me know if it works..!!
Posted on Mar 13, 2009
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
Hanns-G HW191D Monitor - Gives black screen with "No Signal Input" error message. Ever since I hooked this monitor up with my new system, it will randomly freeze (for a brief moment) and give...
You have computer problem, you can easily verify by using this monitor with another PC or another monitor with this PC.
It may be video card driver problem, since the PC was not properly shutdown, it will give you that message "boot in safe mode or normally".
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 17, 2011 | Hannspree HW191D LCD Monitor
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Monitor comes on momentarily then black...tried 2nd monitor same
I suggest you try another video card in your computer. This may be the culprit if the second monitor did the same thing as the first. If the different video card does the same thing, I would then suspect the motherboard.
May 31, 2009 | Samsung SyncMaster 931BF LCD Monitor
Mar 13, 2009 | Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Sep 27, 2008 | IBM Aptiva E 240 (2158240) PC Desktop
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
649 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
