Question about HP Computers & Internet
Boot up problem
Hp 530 cant boot from cd rom eventhough it works perfectly when on.cd drive is also not listed on bios
    Problem Solver:
  • 17 Answers
HI,
There might be a problem with your cmos/bios setting. Try to set to defaults first.
the bios/cmos menu can be entered by pressing del or F2 or F10 keys during power on (before windows logo appears) depending what type of notebook.
find the boot devive or boot sequence,
select CDROM as the first boot ( or first line)
Save and reboot
good luck
Posted on Jan 08, 2009
In my hp 8440P, wen i install har disk, it stops booting even stucks on initial HP Logo screen n dont enter into BIOS even!..Whilst when i remove hardisk, it smoothly boots via cd room..plz help
If the hard drive causes this problem it is most likely defective. Try with another hard drive and if this works, problem solved. I had a bad ROM drive that caused the same problem, I swapped it out and the computer worked perfect.
Aug 14, 2013 | Computers & Internet
I can't change the first booting device as CD drive on my Hp dx220 system, eventhough i have changed in the BIOS it won't boot from CD, automatically it starts from the HDD since the Operating...
You can boot up your laptop with Tenorshare Data Recovery WinPE to recover your files.It allows users to burn ISO file to CD/DVD/USB Flash Drive and boot up Operating System from bootable CD/DVD/USB Flash Drive directly.You can use it to retrieve data under any boot up problem.Get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm Then perform a system restore to fix your operating system.
Aug 03, 2011 | HP Compaq Business Desktop D220
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
Comes up no opererating system.sees hard drive and cd rom.does not read vista disk in cd rom.know cd of vista good,do i just need to change out cd rom drive?
I think your PC is trying to boot from a hard drive without an operating system.
You'll need to change the boot option in the bios from HDD to CD.
When the boot screen comes up, look at the bottom of the screen, it'll say something akin to
Select "DEL" for SETUP or F2 for boot options, you can use either, but remember if you choose to change the setup, it will be a permanent change until you reset it.
Hit the requisite button, read the screen to change "The first boot device" to CD. If you change just your boot option, your pc should then boot from the Disk.
If you decide to change the bios (setup) settings you'll need to save and exit. Unless you're very sure, just change the boot option for now.
Mar 26, 2011 | Dell Inspiron 530 Desktop Computer
System reboot
Depending on what bios it has it may not show the cd drive. All you can do is set it to auto or if it has the option to cd or atapi. Then set the boot order so that the cd is looked at before the hard drive and you should then boot off of the cd.
Oct 24, 2009 | Acer Aspire 3610 Notebook
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Oct 21, 2009 | HP Compaq ProLiant DL380 G4 Server
HOW TO FORMAT HP 530 LAPTOP
all u need to do just enter either "Delete" or "F2" button when u turn on ur computer then go to bios section and change the boot sequence to CD-ROM first then save and exit
aftert that put in ur CD-ROM any bootable windows xp cd then it boot by itself then follow the instruction to format it and install new O/S
Jun 22, 2009 | Computers & Internet
Resetting hp530 bios
Hi!!!!
I got an HP 530 with the same problem and this site just helped me to recover my bios password, they are really cool.
Jan 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Hp 530 notebook cant boot from a cd drive
There is one possible reason for this issue
  1. CMOS battery
Troubleshooting Steps
Open the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery. Removed the battery and put it back. This will reset the BIOS setting to default. Change the setting and select first boot device as CD ROM. If that doesn’t work then replace the CMOS battery. After replacing the CMOS battery please change the BIOS setting and select first boot device as CD-ROM.
Dec 30, 2008 | Computers & Internet
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Computers & Internet Logo
233 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
