Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Need parts for ryobi pcn3335
Accelarotor cable for pcn3335 petrol chainsaw serial no 0504000642
oil pump and drive shaft for 42 cc petrol chainsaw pro 42cc sa 08043692
  • Anonymous Mar 22, 2014
    OIL PUMP
    President:
  • 2,692 Answers
Is there another oil pump other than the oem part that fits this saw
There are a ton of aftermarket parts available for everything. What you need o do is get the oem part number, then search on either amazon.com or simply google... type the part number then oil pump in the search menu...
Oct 15, 2015 | Ryobi Chain Saw. 20 in. 46 cc Gas Chain...
Wont rotate
I Would Guess That The Drive Gear Inside Has Broken The Teeth Of It
From Being Forced At Some Stage!
Unless You Can Get Spares I Am Afraid It Is A Throw Away.
Apr 02, 2013 | Ryobi 14" Chain Saw Repl. Chain - Model...
We have a ryobi 4046C chainsaw and the oil is not getting onto the chain. Have removed the bar and cleaned the hole where the oil should be coming out from to no avail. This is a chainsaw that hasn't had...
Re problems with oil feed on ryobi 4046C, Oil is fed by worm drive and this becomes worn. Contact Augmented Agents on 0161 477 3388 and they will assist you with necessary parts. if you don't know which part ring 01628894400 they will e-mail you blow up plan and parts list. The drive cog is a left hand thread and can be nocked off with a drift of some description (I used a screw driver held flat) this then exposes screws to access oil pump
Jan 09, 2011 | Ryobi Garden
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No oil on chain
Oleg; Is this your saw? There is no breakdown for the oil pump the entire assembly is <$9, and the worm gear that drives it was <$1.
A link to a Poulan PP3816 Gas Saw Type 2 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP3816AV-Gas-Saw-Type-2/75.PP3816AV-Gas-Saw-Type-2.1.59.1.html
If the link is not your saw it can be found here.
The IPL (exploded parts list) for your saw is the only detail for the oil system and it is sketchy at best. Oil components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Which oil and how much to ue in cs1800 ryobi
every you top up with petrol top up with chain oil as this will give chains a longer life,
use any chainsaw oil you can get it from places like b&q.
Jun 17, 2009 | Ryobi Garden
Ryobi pcn3335 wont start at all. Not a kick???????????
Hmmm could be a clogged muffler,fuel line, the carb might need to be cleaned or rebuilt or dirty fuel filter or if u have on the saw thers a low and high idle screw setting, usally on the side of the carb that might need to be adjusted.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
330 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
