Question about Sony VAIO PCG-GRT360ZG Notebook
Locating the Wireless switch on my older Sony Viao Laptop
I have an older Sony Viao and a newer model. The new model's wireless switch is on the front of the laptop. However, I CANNOT find the older model's wireless switch. HELP, I am looding my mind looking for it.
    Scholar:
  • 31 Answers
Hi there, my name is Alex and I am here to help solve your problem
On older models, the wireless switch is the Fun key (the key between the bottom windows logo key and control) with number 2. Press those 2 keys together and it should turn on.
I hope this info helps, please let me know if you experience any problems
Posted on Jan 08, 2009
Wireless capability disabled
Can you enable it in Device Manager? Have you tried to reinstall the correct driver?
Apr 21, 2013 | Sony VIAO Laptops (Laptop NOT Included)...
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
Unable to turn on the wireless lan at the Vaio Smart Network. Message appear that "Turn the WIRELESS switch on the VAIO to ON, and then try again'
Dear user,
on sony viao you need to two things:
1st ) manually pull the slider switch in front or side to ON position (see your manual for exact position if this switch)
2) go neat the date on the screen and open options for connections there maybe u know this. and enable the LAN/Bluetooth by sliding the slider on screen
Maybe your ding just one of the two steps hence the problem as described by you.
May 05, 2011 | Sony Computers & Internet
I have an old laptop that has a linksys wireless-b notebook adapter and my new computer with a linksys router attached is a linksys dual-band wireless-n. I can not get the notebook to link to the router...
Most of the newer routers use a newer type of encryption (WPA or WPA2) which is not supported by older 802.11b hardware.
Either set the Linksys router to use WEP encryption, or get a newer 802.11g card for the old laptop which can use WPA or WPA2 encryption.
Older versions of Windows XP also need to be upgraded to Service Pack 3 or apply this patch:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=662bb74d-e7c1-48d6-95ee-1459234f4483&displaylang=en
Mar 22, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Is there a physical switch to turn on and off the wireless capability? Can get network connection but all other computers in my house can?
Some laptop models have the physical switch for the wireless. Depending on the model. Those that do have them, some are located on the left hand side close to the front, some are located on either the front or side(s) and are a push button type. Newer ones are touch to turn the wireless on or off.
Oct 09, 2010 | Computers & Internet
I have a sony viao and its not detecting any wireless networks all of a sudden...HELP!!! I did the reg-cure scan and its still not working :(
First check to make sure the wireless card is on. On many laptops there is a small button, (on sony usually front center) that slides left and right to turn on wireless on/off) A lot of customers make a mistake and hit this and it will knock your wireless out.
You can also check to make sure your wireless card is still installed under Device Manager->Networking
Feb 02, 2010 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Acer 4720,when switched on wifi button,the light for wifi is flash and the funcion is worked.But switched off wifi button,the light is still on.How can i switch off the light?
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
document:
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
notebook
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
jack
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Jan 20, 2010 | Acer Aspire 4720 Notebook
Wireless N and 4 to 5 year old sony vaio's
Any VAIO Computer released 4 to 5 years ago is not equipped with a wireless card that supports 802.11N WLAN standards. All the older VAIO Computer supports 802.11 a/b/g wireless standard. Because of this hardware compatibility issues the Computer is crashing.
For this issue Sony has not released any general update. However, you may visit the Sony site for specific model to check for any update release to address this issue.
Sep 17, 2009 | Sony Computers & Internet
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortalĀ® 1800HW Router...
Wireless network
lmks6666,
so,ur toshiba is the newer one,right?,anyway,as to my source, "wireless n" is not a thing from the past,instead,its a new version(whatever it is,just got to the point it is newer) of a wireless..
of corz u can set up a wireless connection in ur home ..and its ur choiz if ud buy a new laptop or just buy a adapter for ur older pc..it depends on what wud u preder for..
hope i did help.. =)
Apr 07, 2008 | Computers & Internet
Sony VAIO PCG-GRT360ZG Notebook Logo
287 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
