Hi i keep getting a jamming noice on the printer head the head moves freely but i keep geting a funny noise i have checked evrything and see no jam stuck paper and it printed ok yesterday can you help
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this, is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
Note
Be careful to not force the print head to move.
If the print head
is positioned at the far right hand side, you cannot move it. Please
contact Brother Customer Service from "Contact Us".
Note
Use a flashlight if necessary to check thoroughly.
Norman,
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
ivegot a brother dcp-135c printer its saying paper jammed and theres no paper in it and making noises wont let me do anything hope you can help me thankyou
