Question about Maytag Neptune FAV6800AW Top Load Washer
Water spray from lid
I have water spraying from the back of the lid. There are 3 tubes providing water to the lid. The middle one looks like it is too high and partially hitting the lid instead of the hole in the lid.
  • Connie Mathews
    Connie Mathews Jun 01, 2007
    I've tried that, all three are one piece. When I tried, the other 2 were not lined up.
    Thanks for your help.
  • Connie Mathews
    Connie Mathews Jun 04, 2007
    I discovered Saturday that our contractor (now former) dropped a cabinet on it. He was supposed to install it above the washer not on it. :)
    The lid was bent in the back, I didn't notice at first because the washer has a lot of curves, we straightened it by using a wood block and a small sledge hammer.
    I would not recommend using this method because it is sooo tempting to use the sledge all over it.
    Thanks
  • 883 Answers
Can you bend that tube down until it is spraying the hole in the lid?
Posted on Jun 01, 2007
My kitchenaid dishwasher the water does not get to the upper rack...and the dishes on the second rack on not clean at all....
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer
Jul 17, 2011 | KitchenAid Dishwashers
WONT SPRAY WATER. WATER SUPPLY OK
Jul 15, 2011 | Dishwashers
Water does not enter upper tier in my portable dishwasher
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Dishwashers
The middle spray arm isn't rotating
Jul 04, 2011 | Frigidaire Dishwashers
Does not spray water like it used to, there is soap left at the bottom
If not, then the spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
The detergent generally needs a water temperature of 140 degrees F. You can use a digital read out thermometer to check the temperature or take a look at your water heater to see the temperature at which it's set. Another trick is to turn the hot water faucet on just before starting your dishwasher. This will assure that there is hot water immediately ready for washing the dishes in your dishwasher and for dissolving the detergent.
Jul 03, 2011 | Maytag Dishwashers
Whirlpool DU1145XTPQA - The Dishwasher runs its cycle properly, but the top rack looks like it didn't even get hit by water, often resulting in glasses and dishes being really greasy.
Jun 30, 2011 | Dishwashers
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Maytag Neptune FAV6800AW Top Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
