Question about Sony STR-DE595 5-Channel Amplifier
SONY STR-DE305 FUSES
Hi! I´m looking for the right fuses (f903, f904) for my sony STR-DE305. If somebody can help me... Thenks!
  • 2 more comments
  • copynow Aug 26, 2008
    there is no led display but red lights go on
  • evan_skwara Mar 05, 2009
    Im not sure where any of the fuses are.  Im looking to replace mine as well in the same model but cannot find anything that resembles what a fuse looks like.  Above and just behind the big black power supply box (im assuming is a small greeb elevated circuit board that says, [FOR CONTINUE PROTECTION AGAINST FIRE, REPLACE ONLY WTH SAME TYPE SAME RATING FUSE, REFER TO SERVICE PERSONNEL]  However, it doesnt look anything liek a fuse.  Underneath it has long thin silver shats which are sodered in from above and sodered in below to what appears to be copper wiring entering the power unit that are encased in a long white plastic piece.  To the left there is some sort of plastic clip that looks removable but the rest of the circuit would be destroyed if i tried to pry it off (not that i even could).  Any idea if I am even looking in the right place?
    i finally found a fuse underneath the power supply.  it says 5A 125V and looks burned.  Im going to radioshack to try and replace it.
  • evan_skwara May 11, 2010
    I replaced the fuse and as soon as i plugged it in and  turned on the power it blew the fuse instatntly....any idea why that could be?
  • 883 Answers
Are these the speaker output fuses...if yes, they should be on back panel. if no, then are you also looking for board mounted fuses on the pc board?
Posted on Jun 01, 2007
Where can I get the schematic diagram for my Sony STR-DE305
Ok go to this site and about 3/4 the way down you will find your model number... the model numbers are in order so just keep an eye on them as you scroll down...
http://www.schematicfanatic.com/samscit/sony.htm
just copy and paste into your browser
Sep 22, 2010 | Sony STR-DE305 Receiver
Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Dec 18, 2009 | Sony STR-DE945 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Sony Receiver STR-DE305
It's very likely it is a fuse - does it work with any other speakers or headphones? Is there any reset on the back of the receiver? If not, unplug it, remove the cover and check the fuse(s).
Rate if this helps :)
Mar 04, 2009 | Sony STR-DE305 Receiver
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
Fuses
have you tried to get fuses from maplin electronics.
Nov 22, 2007 | Sony STR-DE525
Sony STR-DE595 5-Channel Amplifier Logo
1,042 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
