Question about Sony Ericsson K530i Cellular Phone
Phone in inside water so not working
Please retified
    Sergeant:
  • 431 Answers
Dismandle the phone dry it
Posted on Jan 08, 2009
My phone is attacked by virus and i cant open my application manager.
Apply soft reset (flashing) at any phone clinic close to you. Only software can retify this and specialize engineer.
Best regards
Jul 18, 2011 | Nokia 5250 Cell Phone
Hi, please help, when i turn my samsung SGH-F500 on, it keeps on intializing & restarts without booting up.
This means your SGH-F500 Samsung mobile has encounter a software error. To retify this, flashing your phone in a phone clinic close to you as that is the only remedy for you to enjoy your phone back. Meanwhile, one or more application that you installed on your phone is responsible for your cellular not booting properly.
Best regards.
Jun 29, 2011 | Samsung SGH-F500 Cellular Phone
The touch screen not working properly can not be calibrated. please could help me
Usually when touch screens don't work, it is due to water damage. You can bring your phone to your carrier's nearest store and ask someone that works there to check if your phone suffered water damage. They'll check the inside of your phone. If that's the case, you'll probably have to buy a new one. If you're insured this shouldnt be TOO expensive. But if you bring it to the store and it's NOT water damage, they should replace the phone for free!
Hope this helped
Please rate my solution!
- Frankie
May 06, 2011 | Cell Phones
Our samsung DL-P5663W PROJECTION TV HAS BEEN MAKING A LOUD SOUND SOMETIMES WHEN WE TURN IT ON. What is wrong and how do we fix it?
Hello
Normally, DLP Tvs must turn on silently. If your DLP projection TV makes a loud sound [you haven't specified anything about the sound you hear from it, either from its speaker or from inside]; it should be checked and get retified soon, otherwise, there is a chance to get DLP module damaged. If it does happen, it means that your DLP TV is out, because, the cost of DLP will be very high. Get the fault retified as fast as you can. Never switch on your TV, till this fault has been rectifed. you haven't given here enough details of fault, and so, I can't send you a solution to you. OK.
Mar 22, 2011 | Samsung HL-P5663W 56" Rear Projection HDTV
No power, power supply not coming on.
Hello
If power supply is not coming inside your tv, the fuse inside it may blown out. There may be some resons for that. Sometimes it may be to a overvoltage problem. Otherwise due to an overload problem. Sometimes inner components may got shorted, especially mains retifier diodes may be leaked. If this is the condition, you must retify that problem first before replacing the the fuse. A multimeter is needed to check this; and to check for all faults.
Never replace the fuse assuming that the fuse only is blown out. Please understand that there may be a reason for that. If you do so, so many other components in your TV also will get damaged.
As your TV is in "dead" condition; we say this condition thus, we can't predict the exact fault point or assume the suspected fault point in your TV. It is best for you to get a technician at service. Please don't spoil your TV by doing self repair; unless you are fully aware of it schematic diagram. Aiwa TV uses some special components of their own, which cannot be bought from local market. Get it serviced by any experienced service technicians, or send to the authorised service center nearby for repair. Ok.
Oct 19, 2010 | Aiwa TV-S2011 20"
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
The battery is not getting charged while riding.
hi, it is probly you battery, retifier or generator: generators are alternating current ( A C ) and the rectifier changes alternating current to ( D C ) direct current. if the retifier is passing A C then the battery will be no good anymore. testing for A C diconect the battery and check with voltmeter (set at 20 volt D C) if needle shows left hand swinging to right hand and back and fore, then your retifier is U / S unserviable also you will need a new battery, or your altinator is OPEN CIRCUIT, inside the engine the way this works there are 4 magnets 2 are north and 2 are south facing alternatave on the crankshaft and there are 2 horseshoe shaped stators, it starts with north then south and then the current go's one way then the other hence altinating, when a magnet is past near a coil it will produce current, but not direct current. we need the rectifier to change this. with a volt meter it will test the battery for volts and if it is dicharged. hope it is helpful gerry
Sep 07, 2010 | 2001 Yamaha V Star 1100 Classic
NOKIA 6300 FELL IN WATER AND DEAD.CAN IT BE REPAIRED?
What to do is this,
Unscrew the phone,
Get a Methylated spirit and a brush,
Bring out the board of the phone and use the methylated spirit to brush off remaining water on phone.
Keep under heat to dry off,
After board is dried, fix it back and screw back phone.
Am sure after doing this phone will work well.
But if phone still doesn't work ,that means water has damage some component inside the phone.
You will need to consult a phone technician for assistance.
Take care.
Aug 11, 2010 | Nokia 6300 Cell Phone
WT714 error code f11
F-11 ERROR MEANS:  Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.-------
to resolve the error check out:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
May 04, 2009 | Washing Machines
Zenith A25A11D -Tv won't turn on
Check for power supply failure.
Sep 02, 2017 | Zenith A25A11D 25" TV
Sony Ericsson K530i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
