Computers & Internet Logo
Posted on Jan 08, 2009
Vivitar digital photo frame VDF7
Cannot get the photo frame VDF7 to show photos as slide show, have only got small photos on screen.
rickharriss
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 14, 2011
rickharriss
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
449
Points
Select the folder you wish to show. Press enter to show the first slide then press enter again to bring up a tool strip.
Select the picture of slides to auto show the folder. You can adjust the speed in the tool box setting.
1helpful
I have a SunPak SDPF-o8o-OSL frame. When I turned it on today instead of the photos I was expecting, I got a screen filled about 75% with colored vertical lines.0 (It looked sort of llike...
You may have mistakenly started in test mode, I suggest resetting the device, here is a link to the manual, it should have something about resetting the frame.
http://www.retrevo.com/support/Sunpak-SDPF-080-Digital-Photo-Frames-manual/id/23157bh642/t/2/
7helpful
I have a Halina Digital Photo Frame DPF070B with no instructions. The screen will display only one picture, I have to manually advance to the next photo vs. a slide show functioning automatically. I made...
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
Aug 15, 2009 • Cameras
2answers
Does the digital photo frame have it's own internal storage, or do I need to purchase an SD card?
Most digital photo frames have a small internal memory limiting you to the amount of pictures that it can show. If you want to have a slide show of a couple of hundred pictures or more then an SD card would be a good idea.
Regards.
Element Electronics 9 Digital Photo Frame 1/2 screen shows
SEE IF YOUR PHOTO FRAME HAS A "VIDEO OUT" IF SO TRY SHOWING PHOTOS ON YOUR TV.
Mar 04, 2009 • Cameras
I have a 10" frame. The picture that I take with my digital camera is cropped by the frame. It seems to crop about an inch off the edges. How can I fix this. I can alter the picture if necessary.
Depends...
if it's during a slide show, then there's a slide show option "screen fit or fill".  If you are set to fill then it will cut off edges, change the setting to screen fit.
or if it is cutting off all 4 sides when displaying a single photo, you may have the zoom turned on.  Tap actions / zoom and set the zoom back to 1x.
3helpful
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
5helpful
12answers
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Grand Canyon Tech
Grand Canyon Tech
