I have just bought a hoover washing machine in the instructions it says to remove the fixing screws ans cover the holes with the provided caps why when the fixing screws are much more sturdy
  • 15,935 Answers
Because they are there for transport ONLY.
They are not necessary when the macine is in use - in fact will cause damage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My housemate washed two garments in my WT540 AQUARIUS HOTPOINT MACHINE and now water is stuck in the drum and not moving. The door is locked. How do I wash out the water so I can get those two garment
something has blocked the pump I susspect, turn off the machine!!! there should be a small cover or door at the base of the machine, have a baking tray and large towel ready to collect the water, open the pump cover place the tray as close as possible and if you have a small tube inside then remove the plug and drain the water to the tray.if its just the screw cap then unscrew the cap behind the cover anti clockwise, water may begin to empty so be ready to either screw the cap back in or replace the stopper as the water in the machine will fill the tray several times, when all the water is empty check the pump is clear by looking into the hole the water flowed from, remove any obstrustion ( if you have the tube you will also have a screw cap to access the pump filter) when obstuction is cleared, screw caps back in and put stopper in, switch the machine on and select a spin cycle,let it finish and end, this should sort it out.
Dec 06, 2013 | Hotpoint Aquarius WD63 Front Load...
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
Hoover SE230 - How do I remove the top cover?
Can't get the image I'm looking for but if this is like most front load washers, there is a screw in each upper corner of the back of the machine. Removing those allows you to slide the top back and then lift off.
Feb 08, 2012 | Hoover SE230 Front Load Washer
Hoover 201M 5.00Kg Heavy DutyTop load leaks slightly . I cant see any easy way of removing the outer case to look inside to find out where the leak may be. there are only a few screws holding the...
  • Unplug the washing machine from the wall outlet.
  • 2
    Remove the plastic end caps on the left and right sides of the control panel using your fingers, and then remove the screws under the end caps.
  • 3
    Lift the control panel up and rotate it 180 degrees.
  • 4
    Unplug the wire connector from the top of the cabinet and then use a flat-head screwdriver to release the spring clips on the left and right sides of the cabinet.
  • 5
    Tilt the cabinet toward you, then lift and remove. Set the cabinet aside.
  • New top load machines all have the cabinet where it comes off forward and the screws only hold the control panel on.
    Apr 04, 2011 | Washing Machines
    I'm getting an F02 error on my Whirlpool front loading washing machine. How do I fix?
    The F02 error code is for a long drain. (See image below).
    Without a model number I am only able to provide you with generic instructions. I have included a set of illustrated instructions you will need to check drain pump filter. (See images below). Once the bottom panel is removed the drain pump filter cover looks like a gas cap. Remove that and then remove any foreign objects. If the drain pump is clear it probably needs to be replaced.
    Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Hoover Quattro Whisper 1400 washing machine AE 240 I would like to clean the filter as scum builds inside the rubber seal on the door Cant find the filter, no obvious opening
    On the front bottom of the machine there is a plastic 'kick plate' that clips/pushes on. Remove this plate and you will see the filter with a cover secured by a star/phillips screw. Loosen screw and twist this cover off to gain acess. Don't do what i've just done and twist without removing this screw as it breaks it:-(
    anyone who knows where i can get a filter cover please post back!
    Aug 12, 2010 | Hoover Washing Machines
    Hoover performa 1100 ac110 not emptying
    After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
    Remove filter by unscrewing anti-clockwise.
    Feb 06, 2010 | Hoover Washing Machines
    I have a Bosch washing machine (Classixx) which has been problem-free since I bought it just 6 years ago. Today I tried to clean the drain pump to check for debris / fluff. I've never done this before, and...
    look for a small hole in the cover with a wire you can press the release tab.. remove bosch pump cover 1) insert wire in small hole in cover 2) while pressing in on wire twist cover 3) remove cover 4) with the handles of plires twist off pump cover Let me know if it helps or I can go deeper into it.
    Sep 26, 2009 | Bosch Washing Machines
    Error message EC03 appears on cotton cycle after 5 minutes into wash
    I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
    I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
    Jun 01, 2009 | Hoover Nextra HNF 3157 Front Load Washer
    Need instruction for installation pull out faucet
    firs you have to remove the handle
    remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
    take a flashlight and determine if you need an allen head screw or phillps
    remove the screw( be sure to cover your drains so nos small parts get in bottom
    remove the handle
    depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
    whatever remove anything holding the cartridge down (some require a cartridege remover)
    remove, take to store match up new and replace
    by all means turn water of under sinnk good luck
    TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
    Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
    Washing Machines Logo
    43 people viewed this question
    Top Washing Machines Experts
