Amstrad dvd player with NO DISC display
I have a Amstrad player which is only about a year old and now displays (NO DISC) .I have the lid off and the disc spins very slow then stops Is there any thing I can do or is it a writeoff Bernard from Kidderminster
I am a retired Electrian
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Posted on Mar 06, 2008
  • 4234 Answers
SOURCE: mintek mdp1770 portable dvd player
Try cleaning the lens using a cotton swab and alcohol. Other than that there is little that can be done. The optics are having trouble reading the disc. You can confirm this by trying a music CD. If the CD works, it is a good indication that the optics are starting to fail.
Dan
Posted on Mar 19, 2008
jonniewalker
  • 1031 Answers
SOURCE: Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Posted on May 24, 2008
Disc reading display
Have you tryed to clean it wit a lens cleaner. Sounds like just needs a good cleaning.
Hope this helps you
Jan 12, 2010 | Philips DVDR75 DVD Recorder
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Mar 05, 2009 | Philips DVP320 DVD Player
I got an all in 1 universal remote & I cant find the 4 digit code
Universal remotes will not in most cases operate anything but TV sets if they are the cheap ones. The ones that operate more types of devices are mush more costly. Go to the www.remotes.com for more information.
May 03, 2017 | Televison & Video
Dvd player gives unknown disc
thats because its region locked..do the following:
open the lid.
close the lid.
note:
do let me know if it worked.
Oct 29, 2008 | Philips DVP320 DVD Player
Faulty goodmans 1104s dab player
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Televison & Video Logo
Top Televison & Video Experts
