Question about Kenmore 24032\24036 Top Load Washer
Leaves film on clothes
It's almost like a film of wet lint all over clothes.
  • Ron Buice
    Ron Buice May 11, 2010
    Check to make sure it is washing in the wash cycle and spinning in the spin cycle and not just making a noise.
  • 15,935 Answers
Check/clean the pump inlet screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Maytag Neptune Dryer Not Drying Well, Leaves Brown Marks on Clothing. Seems like there may be multiple problems. Suggestions?
Sounds to me like an air-flow problem. Poor air-flow means dryer gets hot and scorches clothes but there is nowhere for the wet air to go, so it doesn't dry well. Check for lint-clogged ducting from the back of the dryer to the outside (or at least check both ends of the duct). Also check for a collapsed or clogged flexible tube that goes from the dryer to the duct work.
An over-heated dryer could also have warped the (usually) plastic lint filter.
Jan 07, 2015 | Maytag Dryers
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
Washing machine spins but leaves clothes very wet.....
Hi!!
Check the drain, it seems that unit is clogged. Some models have an access door for easy removal of lint and foreign objects.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 16, 2011 | Hoover Washing Machines
Washer leaves a film of what looks like paper/lint even after drying. Small particles which are difficult to remove
Try running the washer with no clothes in it with a little detergent. Maybe even twice. Then try it with clothes again. It is possible a tissue or something was in a pocket or something that got "washed" and not all of it got flushed out of the machine yet. There isn't anything like that in the machine to cause that. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Leaves cloths to wet after final spin
I assume there is a lint trap on the unit. There is usually a drain pump, which may have its catch basket filled, or the impeller clogged.
Dec 19, 2009 | Maytag Washing Machines
Cleaning lcd monitor screen
use any soft clothe with liitle bit wet and wipe on screen.and leave it for 10 minutes .
Sep 08, 2009 | Computers & Internet
Maytag gas dryer taking too long to dry clothes
Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
Jan 19, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Clothes are soaking wet at end of rinse cycle
Awesome website, fixed my problem. Thank you, especially in these times where I can't afford to just call the repair man:)
Jul 09, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Robert Rankin
