What are the source codes for making records in C++?
I have to make a C++ program which is RECORDS that add record, search record and sort records in ascending and descending order.
please help me to have a source code as soon as possible.
I need drivers for Sonny VGN-NS150D : WIN XP PROFFENAL SP2
Posted on Jan 08, 2009
Why dont i have an internal recording device?
you have an internal recording device. It consists of a built-in webcam and microphone. to make a recording, use the cyberlink webcam program that's pre-installed on your laptop. you'll find it listed somewhere in the start / all programs list in windows 7. also, for sound recording only, the windows 7 audio recorder is located under start / all programs / accessories / sound recorder. select it and click the red record button. also, windows 7 has a feature or program called problem steps recorder. it records activity on your screen including mouse movement. i don't know if it records sound. to access it type psr in the search window and select psr in the search results, then click on start record.
Apr 14, 2014 | Acer aspire 5733z4851 intel pentium...
Www philips com support
This unit doesn't have a tuner of any sort. Even on the few DVR/DVD recorders that have tuners, the external composite video inputs do not connect to the tuner. To record from the L1 or L2 inputs, you must be using a set-top box (cable, satellite, or digital-to-analog converter for OTA signals) or another video source (video camera or a vcr). Most TVs do not have video output capabilities. If you have one of those, follow the directions for recording from set-top boxes below.
Turn on and set the source to the channel that you wish to record for any set-top box. Then make sure that the set-top box is left on and at the correct channel after you finish setting the frequency, speed and length of time for the recording. Note: if the set-top box is turned off, your recorder will still record the blank video and audio.
What source do you have connected to the VCR?
To record from a video camera or a VCR, set that source to play back at the desired time point. This is best done without the timer. Just start recording and then the playback.
I hope this helps. Please add a comment with your video source for more support.
(My OTA tuner has a energy-saver option that turns off the unit when there is no activity for a while. Since I usually record when I'm either asleep or away from home, I had to disable the feature to get the correct recordings.)
Jul 04, 2013 | Philips DVP3345VB/F7 DVD Player/VCR
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
Sourecode for the record that can sort,search and add
I want code for
Jan 10, 2009 | Computers & Internet
Student library record
Import java.awt;
Import java.applet;
class Book extends Applet
{ String book name="Handbook";
int Book no=50;
int d.o.s=” ”;}
Type ur required body content here.
public static void main(String args[])
/*<applet code=”book” height=500 width=500 ></applet>
this appears to go beyond the scope of troubleshooting
Sep 27, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
I can't record audio.
To record streaming music, you need a program that's specifically made for that. Here's one link to a company that sells such a product:
http://www.nch.com.au/soundtap/index.html
However, you might want to just search on Google for "record streaming audio". Shop around - there are some freeware products, and some that are shareware or very low priced. I just included the link so you could see what one program offers, but I haven't tried this particular program myself. I've used some freeware ones in the past, but they probably don't work with Disaster, er, I mean Vista.
May 11, 2008 | Gateway GM5664 Desktop PC
Will only record 1 channel
hello..please refere to your user manual...and choose the chapter of installing tv-channels...you can use "autostore" and when search is finished and saved..you can sort your channels to the correct program position.......please tell me how it went...good luck...Ron
Mar 07, 2008 | LG DR275 Recorder
Program not Responding
you can delete programs by clicking START then ALL PROGRAMS then look for file the program file you are going to delete let say music match click the UNINSTALL.
Dec 20, 2007 | Musicmatch Jukebox Deluxe v8 for PC
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
