Question about Ricoh Aficio CL3500N Laser Printer
HOW CAN I RESET FUSING AN RICOH 9 FICIO SP9100DN PRINTER?
  • Joseph Micallef May 11, 2010
    What is the error message reading?
  • 58 Answers
You need to call a dealer for this model
Posted on Jan 29, 2009
Ricoh Aficio 1015. Why is it not resetting?
Code 543 - Description: Fusing overheat error.
A fusing temperature of over 230°C is detected for 1 second by the fusing thermistor. - Causes: • Fusing thermistor defective • Power supply board defective
May 28, 2015 | Ricoh Aficio 1015 All-In-One Laser Printer
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
Black line
you can wind the web back - will cause more damage in long run running one without it. to reset the count go into service mode and its sp1902
Sep 27, 2013 | Ricoh Aficio Sp 9100DN Printer
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
Jul 27, 2010 | Ricoh Aficio AP410N Laser Printer
Ricoh 1022 service sc544 i need to reset can anyone help
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• SBCU board defective
Oct 29, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio AP400N Laser Printer Sc 545 off on error
SC 545
A Fusing lamp stays on
The fusing lamp stays on more than
12 seconds after the main motor has
been turned off.
• Defective connection of the fusing
This will not reset by turning of/on must enter sp modes to clear this error.
Due to possibility of fire hazard would be best to have tech look at it
Oct 09, 2009 | Ricoh Aficio AP400N Laser Printer
Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
May 22, 2008 | Ricoh Aficio 450 Copier
Maintenance Reset
On the Ricoh 3713 you can do it on the main board by putting dip switch 101-1 on and then off, entering 97, and pressing the aps key. Then power cycling the printer.
The 3500 is probably similar.
May 19, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
