I left the gps disconnected in the car in the cold for 8 hours. then i tried to turn it on. there was only the welcome screen. i recharged it but it does not respond to switching off or on.
i used my tomtom go 700 when using it suddenly the lights goes off then i'll try to turn on again then it dosnt work i though its the battery low,when i charge it the green lights is on but it dosnt turn it on.pls you can help me thats will be great help.thanks
Same issue. Working one time then dead the next. Green light comes on when charging but cannotg boot the gps at all. Help PleaseSame issue. Working one time then dead the next. Green light comes on when charging but cannotg boot the gps at all. Help Please
You can't post conmments that contain an email address.
If your Nuvi won't turn on, it's possible that it's locked up. Try using the reset button as follows.
Nuvi 3xx & 6xx Series: The reset is located on the rear of the unit, underneath the antenna. Press and hold it for at least 8 seconds and then release.
Nuvi 7xx Series: Slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Nuvi 2xx & 2xxW: There are (2) different versions of this series.
Some will have the reset on the bottom, where the decal is. There will be a small flap labeled "reset".
On newer units, slide the On/off power switch to the left and hold for at least 8 seconds and then release.
an reset or an update might fix it, but if it doesnt, its still under warranty!
turn on your 5310 and locate the reset on the bottom left of your unit (small pinhole) use a paperclip to insert and depress the reset switch.
if that fails and you want to try an update, you can get the 4.72 update HERE you have to sign in and register before they will let you download anything.
to send it in for warranty repair or replacement call the number listed below.
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
Dont leave sat nav in car as it kills battery,try removing memo card if installed hold in reset button few seconds ,reinstall card if fitted and try boot up
Try holding the power slide to the left and holding it there for 8
seconds. If that doesn't work, try charging it via your PC & USB
cable. If that doesn't work, try a mains charger if you have one (I had
to do this with mine). Good luck!
GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
The company went bankrupt. I get a "unable to read map data error". Called for over a month, sent email after email. Finally contacted a company that fixes Finedrives and they told me the company (Fine Digital) is out of business and will not warranty the unit...ten months old at the time. The company who fixes these machines said that it would be cheaper to buy a new(different company) gps system compared to having them fix the Finedrive 400.
