I have gormattedg my system with XP cd which is not given by sys but mine speakers r not working. what should i do?
  • pavani_reddy Jan 08, 2009
    but it takes for me lots of time to do around 6 hours so will u pls tell me another solution.......
    i had solved my problem from other sources
    thanks for giving me information
    thanks a lot:-)
  • 40 Answers
Hope u mean u have reinstalled xp on your computer. After re installation you need to install the motherboard drivers and the driver for your audio. You will find these in the disc you received along with the motherboard. Lemme know whether this works for you. Thanx n regards
Posted on Jan 08, 2009
  • Arish Shareef
    Arish Shareef Jan 08, 2009
    well, to be frank that's the standar procedure for a correct OS instal. Do it once correctly then you won't have to bother till your next re installation.
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
I installed WIN 7 operating system to my PC - Mercury PVM900M(Kobian), but out of 4 speakers,only 2 speakers are working. also i could not able to install drivers cd which was working fine in XP
Sometimes the drivers are not compatible with windows 7. Use a driver finder tool to download specific updated drivers for hardware. Also use as sytem utility tool like Reginout to fix registry and other windows errors. Maybe windows causes the problem for driver installation.
Apr 23, 2012 | Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
When I plug the "doggle"
have you ever used the doggle on a different system? do you have a software cd to install along with the doggle?
Please let me know so that I may continue to help you.
Jan 09, 2011 | Saitek A-250 Computer Speakers
Altec Lansing Sound On Sony Vaio Not Working
Are you running Windows XP?
I recently had a customer with a similar problem on an XP desktop; I tried all sorts of fixes before finding the answer in an online forum - it was a problem with the 'Software Enumerator' see the link below and look for a post by 'Jurekos'
http://www.techspot.com/vb/all/windows/t-34101-The-driver-has-been-enabled-but-has-not-been-started.html
Or follow the summarised steps below:
- FIRSTLY CREATE A RECOVERY POINT IN CASE IT DOESN'T WORK AND YOU NEED TO UNDO CHANGES -
1. Check if PnP SW Enumerator is installed on your machine (Device Manager / System devices) - it should be listed there!
2. If it is not there then we will probably solve it!
3. Locate "machine.inf" on your OS, copy it somewhere and modify it as follows:
(find "ExcludeFromSelect=*" and remove the line or simply exclude it from processing by adding a ";" at the beginning)
4. Check the "machine.inf" file for location where SWENUM should be located (mine was reading: SWENUM.CoInstallers.CopyFiles = 11 ; %windir%\System32)
5. Find "swenum.sys" file on your XP installation CD (mine was in DRIVER.CAB) and copy it to the proper location (I am not sure if it is necessary but worked for me) You could also copy this file from someone else's Working copy of Windows XP if you don't have your installation CD
6. Go to Control Panel /Add Hardware and follow the wizard towards manual selection of device to be added
7. Select Add System device
8. Select Have disk
9. Navigate to changed machine.inf
10. from the list select standard devices (in the left list) and "Plug and Play Software Enumerator" in the right list
11. Finish the installation
If it still does not work reinstall the audio adapters' drivers
Post a reply if you don't understand any of the steps listed and I'll try to explain in more detail
Good Luck - John
Sep 16, 2009 | Acer Veriton 5600G PC Desktop
I am having trouble running setup on my desktop
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Pci.sys
ya you can transfer that file but it is difficult as usual... you need to some dos and using this dos windows you can copied that file into your c: drive...
but i suggest try to repair with any xp cd
Mar 30, 2009 | Toshiba Satellite 4300 Notebook
Kingston dti/1gb
Have you tried finding the drivers for the USB Flash Drive?
Sometimes XP may need a compatibility drivers.
Mar 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
USB
checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Aug 18, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
