Question about Compaq Armada M700 Notebook
Format a compaq armada laptop
How can one format a compaq armada?
also what is the best windows to install after?
Im mostly a home browser. can you help?
thankyou
  • 54 Answers
I would recommend Win2k for your system. Just a personal preference on older systems. Both XP and Vista are fairly visual and the Armada line weren't too beefed up with processors and such. As far as formatting amusedgeek here gave you your best bet. I know there is an option through My Computer and by right clicking on your C:\ drive but if I remember correctly attempts at that were unsuccessful.
Good luck.
Posted on Jan 14, 2009
  • Compaq Master
  • 787 Answers
This is an older system so Vista is definitely out, it MIGHT load but it would be really slow.
Best bet is probably XP Home, you could install Windows 98SE but a lot of the newer programs will not work with it.
Boot to the installation CD, you will have the option to format the drive as part of the installation procedure.
Device Drivers for your computer are located here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=96721&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=96235
I suggest you download them and burn them to CD first because you network adapter may no work after the reinstall until you load these.
Posted on Jan 08, 2009
Trial Product Code won't enter Window 2007 office home/student
It is possible that your installation of the Office program may have become corrupt. The best thing to do is to contact Compaq support and have them give you another trial code. If that should fail they can then send you another copy of the trial program for a re-install.
Mar 11, 2010 | Compaq Armada M700 Notebook
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
Time bomb virus in compaq armada M700
try to reset the bios to default settings, and try to reinstall again
regards
Nov 17, 2008 | Compaq Armada M700 Notebook
Need Instructions on this...
In order to upgrade to XP with a fresh install, you will need to purchase an XP disc, then it's simple. Upon start up you need to go to the boot menu or set the cd drive to boot before the hard drive in the bios. Then insert the disc and follow the directions. At one point, you will need to delete the existing operating system in order to install the new. Once this is done, then you will need to format the drive using the full NTFS format, not the quick format. Then it's all down hill, just follow the direction. After the install, you will need to go to Compaq's support site and download any drivers needed. You can find the needed drivers in the device manager. I realize you would like to get around the XP purchase, but unfortunately, there's no way around it.
Aug 20, 2008 | Compaq Armada M700 Notebook
Install xp-sp2 on compaq e500
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
Need software
Your only hope is that you have a Windows XP pro installation disk to either repair or re install Windows, although a repair is only of use if you still have the principal windows installation. How is XP still there if the notebook has been formatted? If your recovery disk ;which I recon was on another partition on the hard drive is long gone, then the only solution is to purchase XP, although XP home is a cheaper, but just as good a version please rate this solution.
Nov 13, 2006 | Compaq Armada E500 Notebook
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Compaq Armada M700 Notebook Logo
225 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
