Question about D-Link AirPlus DI-524 Wireless Router
D-Link DI-534 Starting up problems
Starting from completely disconnected router.
1st Attempt:
I plug in internet and desktop computer.
Connect power to router.
All lights are on except Status and WLAN.
I wait approx. 5 mins and nothing happens.
LAN connection states that LAN cable is unplugged, swapped cables and connections and no results.
2nd Attempt:
Disconnect everything from router.
Plug in power source only.
Same result as 1st attempt..
3rd Attempt:
Set up router as I did in 1st attempt with computer and internet.
Plug in power.
Same result.
Reset the router.
All lights clear.
Power light comes on about 2 seconds after reseting with WAN and 1st jack light.
Status light has a steady 1 pulse per second starting about 5 seconds after resetting.
After Status Light starts pulsing, The port that the LAN cable is connected to will start flickering about every 10 seconds with activity but will not connect completely.
Unable to access the router, and LAN connection saying limited or no conductivity, when I try to repair it states unable to renew IP address.
WAN sight shows activity like expected, almost constant flickering with brief pauses of constantly being lit (similar with other routers I've had that have worked normally).
I have restarted my computer, restarted the router, reset the router, changed cables and connection plugs (Desktop has 2 ethernet cards) and jacks on the router with the exact same responses.
Is there anything else i can do or am i completely screwed on this one?
  • 3 more comments
  • nexisone Jan 10, 2009
    I was unable to update the firmware as in I cannot even access the router at all (unable to assign IP address and get cannot display page when I put in the router IP on Internet Explorer). I also do not know how to reflash the router, but im willing to try anything at this point.
  • nexisone Jan 11, 2009
    Ok I dont know what happened. But i went to do as Joker said and when I intially plugged in my router it worked, perfectly. I have printed off your solution and will keep it in case it happens again. In the mean time im gonna update the firmware and hope for the best
    Thank you guys
  • sxxxs May 11, 2010
    Did you try resetting it
    back to defaults.
    Go here and select your
    router. From there you can read the manual and see how to upgrade and reset you
    router.
    Did you try updating the firmware? or reflashing the same one?
  • 49 Answers
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Posted on Jan 10, 2009
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have been using my DI-524 for about two years now without problems. I went away on vacation, left my computer and routers running and now when I get home I cannot connect nor see the wireless connection...
When you say your rebooted the modem and router, do you mean you power cycled them both? If you're unfamiliar with power cycling, this the technique:
1) Unplug your main Cable or DSL line from your modem.
2) Unplug the power from the modem.
3) Unplug the power from the router.
4) Wait about 20 seconds.
5) Plug the Cable or DSL line into the modem.
6) Plug the power into the modem.
7) Plug the power into the router.
Make sure that all computers are shut down and completely off. After you have power cycled, reboot the computer(s). If you still do not see the SSID (the name of the network), then someone probably hacked into your router and changed the password. Here's how to overcome that:
1) Unplug the power from the router.
2) Press and hold the Reset button on the router for at least 30 seconds.
3) Plug the power into the router.
4) Open an internet browser (Internet Explorer, Firefox, etc.).
5) Type in the IP address of your router. For this router the IP address should be 192.168.0.1
6) You should be at a login window. The User Name is admin and leave the password blank.
7) You should now be in your router's configuration options. You should enable the highest security possible, then change the default User Name and Password to something secure, with letters and numbers.
My information for you router came from this link:
http://www.myacrobatpdf.com/8429/dlink-wireless-router-dl-524-setup-instructions.html
Jan 13, 2010 | D-Link AirPlus DI-524 Wireless Router
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
DI 514 wireless router not working with my linksys SPA 2102 voip
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Aug 23, 2009 | D-Link DI 514 Wireless Router (DI-514)
I have DI 524 d-link. Internet works on desktop and one laptop. Just got a new laptop and everytime I try to connect on the network of 1st. laptop, it says connected with limited access. unable to have...
Make sure that every setting in the new laptop matches the settings in the router. If one setting is off, you will not get a connection. It is also possible that the router is set to only allow specific computers to connect to it. If that is the case you will have to add the new laptop to the allowed connections in the wireless settings of the router.
Aug 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can't connect to default network.
Try to power cycle your router. Unplug the power for 30 seconds then plug it back in. If that doesn't work, try to change the channel of the router. That should do it. If it still not working, there's a problem with wireless adapter's driver. You need to use update one.
Nov 02, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus DI-524 Wireless Router Logo
1,788 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
