Question about SanDisk Memory Media
How will i reformat a sandisk mobile memory stick duo
My memory card makes my phone hang so I can't insert and use it.
  • 31 Answers
If its messing you phone up take you phone and have it checked and make sure it will read the card and as for the card trash it and get a new one they wear out fast if you take alot of pix and transfer them alot the cards are only good for limited usage you might be able to format it 5-8 times b4 you have to junk it i'd get a 2 or 4 gig sd card to hold more so you dont have to format as much but as for formatting it put it into a card reader on your computer and right click the drive in you my computer and click format
Posted on Mar 27, 2009
When i remove memory card and insert or switch on and off my cell phone all the data in memory card is losting. please give me some suggetion.
Firstly switch off your mobile.Then put out your memory card adapter from your mobile.then re-enter the memory card adapter in your mobile, but sure of that if your small lock in your adapter is unlocked.It is unlocked by hand.Then ENJOY.
Jan 02, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    Plz help me!
    sony is for sony, reformat it
    Mar 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
    My san disk m2 2gb memory chip makes my sony ericsson w205 phone freeze up but when i take it out th phone works fine.
    this is a common problem for most of the phones you just insert the 1 gb card which was given to you with the phone
    Oct 25, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    SanDisk memory stick pro duo 4GB not reading
    does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
    Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
    I did a reformat but still my phone cannot detect the memory card
    1. If your memory card can be detected on your computer, then try to completely format the card.
    2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
    Start >> OK / Yes (confirm the request!).
    3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
    4. You should replace that memory card with a compatible one!
    please rate this advice if it helps...tc! :)
    Sep 24, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    The SD m2 2gb Micro does not work on my phone
    the card shows sign of a rom ic being lost its firmware
    Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Computer does not recognize the M2 micro memory stick san disk
    1. It means your computer is not able to access your phone!
    2. Memory card seems to be working properly!
    3. Try to reinstall the phone driver software on your computer.
    4. Restart the system and check again!
    Aug 30, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My sandisk m2 does not get regognised on my mobile phone.
    You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
    If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
    Have a great day!
    Aug 16, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My phone is not detecting the memory stick micro
    Format the memory card in pc or any other phone then insert in your phone it will work.
    Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Electronics - Others Logo
    97 people viewed this question
    Top SanDisk Electronics - Others Experts
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
