Question about LG RU-42PX10 42 in. HD-Ready Plasma Television
Red line on left side of plasma bright two inches wide
The line runs from top to bottom modle RT-42px12x lg it said it has 60,000hours no way can you please help is it a fuse?
  • 1 more comment
  • frith644 Jan 12, 2009
    the lg is 08/05 thank you anyway frith644
  • Anonymous Apr 05, 2009
    yes i have the same problem plus a blue line on the right side of the screen
  • Anonymous Apr 06, 2009
    I have the same but a red & Blue strip on the right side
  • 179 Answers
Either the address board or the panel has gone bad.
the problem is that many times the address board is part of the panel. if it is under 2 years old you need to
get with lg and push for a new panel
Posted on Jan 08, 2009
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Sep 18, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines on LG-DU-42PX12X
please change vertical ic oc decosition coil solderd
Aug 07, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG RT-42PX10 plasma - No Display
Power supply on left hand side module. check if heatsinks are cold. possible faulty. fuses and input voltages first check.
Mar 18, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Have sound, but only bright mostly yellow vertical lines on my LG DU-42PX12X .
Since I haven't heard back ,I am clearing this from my queue. Best of luck.
Apr 12, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-42PX12X Verticle lines of various colors, and widths throughout the screen.
Check within you area for a reliable LG repair center. To fix the problem of the blue, red or green vertical line you just need to replace the control board PN 6871QCH038C. The part cost about $150.00 and a honest repair center should not beat you up to bad on the labor. Good luck and Good viewing.
Feb 06, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
May 23, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
201 people viewed this question
Computer Repairing
Computer Repairing
