Question about Samsung Washing Machines
Water won't drain to progess to spin cycle
My Samsung washing machine will not drain the water to progress to the spin cycle. All filters and drain hoses have been checked.
  • 146 Answers
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Posted on Nov 03, 2007
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
  • 26 Answers
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
Posted on Oct 04, 2009
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Maytag MAH8700 pumps the water out of the tub but then tries repeated to keep pumping water and will not progess to spin cycle. It will do this and then sometimes (not all) display the nd error code.
Edit your posting to add Make and Model#
Check your manual for troubleshooting tips or search online for your make and model# to find a manual.
Contact the company of your product or a local appliance shop to ask them.
May 12, 2015 | Washing Machines
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
If this does not help, the drain pump may be faulty.
Kind Regards
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
Kind Regards
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Kind Regards
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
Aug 01, 2011 | Samsung Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
My GE washing machine is stuck on agiation mode.
Jul 15, 2009 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
