Unknown disc error
Some DVD okay. Other not playing with message unknown disc , please check disc again.
DVD playing okay on other dvd player I get an error message "unknown disc" on any DVD discs I have not tried before in my LG RH2T250 DVD Recorder.
  • bransonp Jan 09, 2009
    That still does not explain why it will play any DVD that I have previously put in it but not new DVDs
    All DVDs both old and new are the same region. I have tried all my DVD collection and the only difference between the DVDs that will play and those that won't is when I last played them. Any played in the DVD prior to 3 days ago will play. Any new ones I had not played yet produce the "unknown disc" error when put in. Is there a DVD memory in this model (LG RH2T250) that I can access or reset?
    Brigadier General:
  • 5,158 Answers
Are these prerecorded dvd's as in store bought or copies ?
You may be running into copyright issues
Posted on Jan 09, 2009
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is blind for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating but it is still better to give it a try.
If you see dust on the lense, then its just that simple. clean, close, play.
check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
  • 6,487 Answers
This can be a region problem, because some DVD are made for a different region for example your DVD player will only play those DVD that are region one so if your new DVD are region 2 your player wont be able to play it, you need to make your player multi region so you can play all DVD from different region..
    Scholar:
  • 89 Answers
Disc may be slightly dirty or scratched and eye in disc player may not be able to read the disc, or the eye itself is dirty. You can purchase a cleaner for your machine. It consist of a disc with little brushes attached to the read side of disk so that it sweeps the eye clean, this should do the trick. Most care/cleaning systems are inexpensive and last a long time if cared for properly.
Philips Blu Ray Model HTS3541/F7 Unknown Disc error
Check with an other known good disc. If it shows the same for that disc too, its laser pickup unit has the fault, and should be replaced. Contact any experienced service technician. Replacing laser pickup assembly to blu-ray players are a very very skilled work. http://electronicshelponline.blogspot.com/
Jul 16, 2016 | Philips Televison & Video
Unable to get any dvd to play.
It should also play---most likely a dirty or bad Optical Pickup in the unit---try to record a disc and play back on another unit?
Nov 02, 2012 | Televison & Video
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Oct 28, 2007 | Philips DVDR630VR DVD Recorder/VCR
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
