Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
I cant receive call with opening a slider
So i have to always use green button to receive a call
  • 42 Answers
You have to go into the setup menus and locate where the actions of the slider are defined.
Posted on Jan 08, 2009
  • Raj Jan 09, 2009
    Can you please rate my response. Thank you
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
How do i install my sd card
open the slider, and on the side of the phone next to the green phone button, there is a little plastic cover flip it open and you can put in your sd card there :) hope tht helps!
Oct 16, 2009 | HTC G1
My volume has gone also cant get volume on
First check you dont have a red line through your speaker on your toolbar. If so click it and "UN-mute it.
If using external speakers then check that the speakers are plugged into the GREEN port on the laptop and that the speakers are powered up with the volume at about 1/2 way.
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Make sure that Volume controls, Wave, SW Synth, CD PLayer, Line IN, and MIC all show on there and that the volume sliders are about half way up.
Make sure noe of the sliders have ticks at the bottom, if so UNTICK them.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else unles you know you want that item)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
If not double check that you have no problems with your hardware from the device manager.
Sep 12, 2009 | Compaq Computers & Internet
I cant get sound on my computer
Check that the speakers are plugged into the GREEN port on the back of the computer and that the speakers are powered up with the volume at about 1/2 way.
Click PROERTIES
Sep 06, 2009 | Acer Audio Players & Recorders
All my dad's pictures are coming out blue-ish green...
open the camera; set dial to 'I'; press the up button on the menu until 'exposure' appear; press once again until 'red-blue' slider appear; move slider to left/right in order to get the colour you want.
Sep 28, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
My back button does not work
****! I got the same problem!!!
Oct 24, 2007 | Kyocera Slider Cellular Phone
DSC-S40 , my camera wotn switch mode.
If you opened and unable to find the switch, then the switch might be snapped, or the sw slider was not aligned to the sw itself. you can find it by aligning the sw slider of the back cover to the main board, its a very small switch soldered on the board near the upper portion of the LCD panel. If you find it, slide it to leftmost, at the same time, move also to the leftmost the sw slider at the back cover. Assemble it carefully, thanks
Aug 13, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
